Warm engine idles faster and faster
- fergyfer
28 Oct 2005 07:49
I don't know if this is normal, but after I warm the engine up enough to ride, the idle is rough and low, around 1100 rpms. When I go a few miles (on the road the bike runs great) 6-7 or so, and come to the first stop, it is usually idling much higher and smoother and by the time I get to work, another 5 or so miles, it is idling around 2300 rpms. Seems like I'm always playing with the idle stop screw to lower or raise it. Is this possibly just a sign of carbs not in sync or floats not adjusted right? I have not yet aquired the carb balancing equipment needed to do that...
- Old-Skul
Re: Warm engine idles faster and faster
28 Oct 2005 17:35
A carb cleaning and synch might help.
But if the bike isn't stock (pod filters, or other mods) this is pretty common. Changing to a different spark plub (either colder or hotter) by one range might help as well.
These air cooled motors seem to carburate very different as they warm up. I usually set my idle so the bike idles correctly when fully warm, and then just blip my throttle at the the first few traffic lights I get stuck at on the way to work!
- z19OO
30 Oct 2005 12:30
Thats a big jump in idle........did you ever reseal the intake manifolds? You may be leaking air causing the different rpm's.
1975 z1 900
1979 kz650b
1979 kz650b
- wiredgeorge
30 Oct 2005 12:35
Doug, If you look back at threads on the Teikei carbs used on your bike, they are notoriously slow warmers. Set the idle when the carbs/bike is fully warmed. When the bike is warming, operate with a partial choke or let it idle for awhile longer before riding off. If you can ever take a bit of time off, ride down this way and I will have a look at things if you like.
- fergyfer
31 Oct 2005 06:54
Thanks all! I do remember reading about these carbs being slow to warm. I went ahead and turned in my idle mix screws and backed them out 1 1/8 turns like the Kaw manual said and it made a huge difference. I had previously just returned them to where they were, about 1 3/4 turns. I adjusted the choke/idle screw this morning while warming up and it really kept things smooth. I did adjust the big idle wheel after it warmed up yesterday, down to a normal idle. We'll see at lunch how it does but I think I have it pretty good now.
Thanks again!
Thanks again!
