wont start with starter
22 Nov 2011 21:39 #489756 by wcrider62
wont start with starter was created by wcrider62
Attachment HPIM1763.JPG not found
Attachment HPIM1765.JPG not found
Attachment HPIM1767.JPG not found
Attachment securedownload_2011-11-22.jpg not found
I got a 82 kz 1100 spectre d1. been changing alot of things. I got spark , I fixed the boots between the carbs and the motor. with a little help pushing- dang thing is heavy- I can get it to start and she runs great and and after warmed up I can puish start her easy by my self. I bought a starter and cylinoid and new battery and she wont start with the starter.been snowing and cant get help to try pushing again even if the streets were dry I've gone through and re-gone though every thing I dont know how many time now. what the h%#$l am I doing wrong??? can anybody help me- any ideas??? I starting to get gray hairs in my beard over this. please , any ideas are welcome thanx
1982 kz1100 spectre D1
  • Motor Head
22 Nov 2011 21:46 #489757 by Motor Head
Replied by Motor Head on topic wont start with starter
Is the engine turning over with the starter? Or is it not turning?
If turning the motor, then is it slow? Or does it spin it and it just doesn't start?
22 Nov 2011 21:59 #489759 by wcrider62
Replied by wcrider62 on topic wont start with starter
the motoer is turning over and it seems mabye a little slower than it should
  • Motor Head
22 Nov 2011 22:09 #489762 by Motor Head
Have you tested the voltage to the Red wires at the Ignition coils? Maybe when cranking with the starter, this voltage is dropping down.
If it is cranking slowly, measure the voltage at the battery, then move you positive test lead to the post on the starter motor. Note the difference. Possibly the cables are causing the starter to receive less than battery voltage under load.
Also have you had the carbs apart? Clean, and bench set/ synced? Have you checked compression? Valve clearances? What does the spark plugs look like, New?
23 Nov 2011 01:25 - 23 Nov 2011 01:37 #489788 by wcrider62
kind of confused . I ran the testor from red wire at coils and the black one to neg on battery got nothing ran it to poss on battery and got 12.45 both sides but getting spark at plug . question -- I got blue,black,yellow and red coming from pickups going into egnigtor but have a black with yellow strip , gree, black and yellow with red strip. aint there suposed to be a red coming out too ?? and I got i ohm at pickups had to come back on edit almost forgot when testing at the pickups , while trying ti find a place to touch with the probe to get a reading at one spot a kinda high piched buzz/whining noise started coming from somewhere in that earea. I didnt want to keep makeing it happen to find exactly where for fear of berning something up
Last edit: 23 Nov 2011 01:37 by wcrider62. Reason: for got a detail
