Leaky Boot but no cracks?
  • KZ7hundy
  • Topic Author
  • 1984 KZ700
21 Nov 2011 16:55 #489511 by KZ7hundy
Leaky Boot but no cracks? was created by KZ7hundy
So i had a slow fuel leak coming from one of my intake manifolds and i removed it to replace it but I see no cracks or damage at all. Could it still be faulty in some way?
21 Nov 2011 18:14 #489519 by P21
Replied by P21 on topic Leaky Boot but no cracks?
slow fuel leak would be a stuck float or level too high.
what does the air box look like wet with gas?
Kawasaki KZ 1000 Police (2002) P21
  • clutch
  • I wish I had a tad more patience to do it better!
21 Nov 2011 20:29 #489557 by clutch
Replied by clutch on topic Leaky Boot but no cracks?
+1
Check your float level. Gas should never be leaking out of intake boots.
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
  • KZ7hundy
  • Topic Author
  • 1984 KZ700
21 Nov 2011 20:33 #489558 by KZ7hundy
Replied by KZ7hundy on topic Leaky Boot but no cracks?
Yes the airbox had some gas in it. I replaced the boot and no more sporadic idling or rough riding in 1st gear so the vacuum leak is fixed. Do I still need to be worried about a slow leak now though?
  • clutch
21 Nov 2011 20:35 #489561 by clutch
Was it only leaking while running? I don't think I've heard of fuel leaking through the boots, unless it was from a stuck, or improperly adjusted float level. It only takes a few minutes to check, so I would double check that before assuming it is fixed. :)
Wish List:
Z1 (need I...
  • KZ7hundy
  • Topic Author
  • 1984 KZ700
21 Nov 2011 20:43 #489565 by KZ7hundy
i just took it for a ride then went out now to see if it was leaking and there's nothing as of now. what do you think?
  • clutch
21 Nov 2011 20:47 #489568 by clutch
If you have a vacuum petcock, or even a manual one that is turned off, the gas will only leak with the petcock on (engine running for vacuum). It's up to you, but personally I would check to make sure it's set right.
Wish List:
Z1 (need I...
21 Nov 2011 20:51 #489573 by P21
Attachment CARBFUELLEVEL8-27-11004.jpg not found
it wouldnt hurt to do a clear tube test then you know for sure
  • KZ7hundy
  • Topic Author
  • 1984 KZ700
21 Nov 2011 21:42 #489582 by KZ7hundy
sounds good. i'll see if i can give it a shot. thanks for the help boys
