anything special about 83 750 gpz carbs?
- ramtough_63
20 Nov 2011 01:13 #489292
by ramtough_63
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
anything special about 83 750 gpz carbs? was created by ramtough_63
talking to a guy who wants to buy my 83 750gpz engine complete but i have a carb that the float sticks and leaks out the overflow. anyway i know certain carbs can be expensive to get parts for and certain carbs can be worth more money etc.., I know nothing about the various carbs and combinations. I have no clue what carbs I have. any help on this matter would be appreciated
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- Thank you received: 2098
20 Nov 2011 01:53 - 20 Nov 2011 10:17 #489295
by Patton
Gasoline discharge from the overflows more often results from a float valve issue (such as crud at the interface between the float needle tip and the float seat) as opposed to a "sticking" float.
Might possibly result from a worn float valve, or a float tang setting that allows a far too high fuel level, but these causes are less likely, imo.
Sometimes able to clean the float valve by using SeaFoam in the fuel. Or opening the drain and allowing fuel to flow through the carb and from the bowl in hopes that it may clean the float valve.
Another possibility is a crack in the overflow tube (which is often repairable).
While the engine is at idle rpm, could try rapping smartly against the subject carb's float bowl with a plastic hammer or large screw driver handle. Which might jar, loosen and flush away any crud at the interface.
When the float itself is "sticking," such condition would generally not happen out of the blue, but likely result from the float apparatus being bent or damaged when being removed or re-assembled into the carb.
A "leaking" or "sunk" float could also result in overflow, because the float then fails to rise up and close the float valve (press the float needle into its seat).
Replied by Patton on topic anything special about 83 750 gpz carbs?
ramtough_63 wrote: talking to a guy who wants to buy my 83 750gpz engine complete but i have a carb that the float sticks and leaks out the overflow. anyway i know certain carbs can be expensive to get parts for and certain carbs can be worth more money etc.., I know nothing about the various carbs and combinations. I have no clue what carbs I have. any help on this matter would be appreciated
Last edit: 20 Nov 2011 10:17 by Patton.
- steve.w
20 Nov 2011 07:14 #489310
by steve.w
Replied by steve.w on topic anything special about 83 750 gpz carbs?
hi mate nowt special about carbs theyre 34mm mikunis .. bought a set last week from an auto jumble for £20 (bargain) but theyre fetching about £40 on ebay in uk which still isnt expensive .. steve
- ramtough_63
20 Nov 2011 12:43 #489332
by ramtough_63
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Replied by ramtough_63 on topic anything special about 83 750 gpz carbs?
thanks guys was making sure they weren't some highly drsirable part the guy was gonna screw me our of or get me to drop my price by crazy money he can either buy it at my bottom dollar price or i will use it for a ptoject. motor runs strong eben with minot carb issue
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- mtkawboy
- Thank you received: 16
21 Nov 2011 18:26 #489521
by mtkawboy
Replied by mtkawboy on topic anything special about 83 750 gpz carbs?
Pretty much a std BS34 CV Mikuni thats jetted different with different needles, air jets & pilot jets. That and its painted black, at least my 82 GPZ750 is. Nothing a cleaning and checking the float level wont cure on yours Im sure. At the most a new needle & seat maybe but I doubt it. Spin some light valve grinding compound between them if it isnt rubber tipped
