83 KZ750 running issues...
- dylan_kz750
17 Nov 2011 22:26 #489011
by dylan_kz750
83 KZ750 running issues... was created by dylan_kz750
I purchased my bike a couple weeks ago and have been riding it a little here and there, but after a long ride it'll end up bogging down and eventually turning off(like it's running out of gas). I'll let it sit for a while and it has trouble starting but eventually cranks up again, runs fine for a while(maybe 30 or so miles) and bogs down again. I know I need to go through the carbs and there are a couple things here and there that need to be adjusted, but why would it keep starting up fine and run for a while and then shut off? Here are a few things to know...
-When I went and looked at the bike it was idling really high, so I adjusted the throttle a good bit and it calmed her down a great deal(I was thinking, maybe it was running too rich and flooding after riding for a while?)
-I've replaced the fuel hoses and fuel filter
-Topped off with high test and ran some fuel system cleaner through it(not seafoam, would that help? I've heard mixed opinions)
I'm not a first time bike owner, but a first time OLDER bike owner and would love to do as much as I can myself.
ANY IDEAS?!?
Thanks in advance for your help!
ANY IDEAS?!?
- Motor Head
- Thank you received: 391
17 Nov 2011 22:32 - 17 Nov 2011 22:32 #489014
by Motor Head
Replied by Motor Head on topic 83 KZ750 running issues...
Fuel line/ filter restriction, or tank Vent blocked. Remove your Fuel line from the carb TEE and see what the flow is. Compare to no Inline Filter, you may have gotten a filter for a pressure, instead of gravity system. then it could be the Screen in the Tank, above the petcock, that's worth checking. Then there are small Screens above the Float Vale needle and seat assy, at the carb inlet.
Last edit: 17 Nov 2011 22:32 by Motor Head.
- dylan_kz750
17 Nov 2011 22:45 #489017
by dylan_kz750
Replied by dylan_kz750 on topic 83 KZ750 running issues...
it also happened before I replaced the fuel filter. I don't know if that would make a difference. Thanks so much though, that gives me something else to check and I sure hope that's the only issue. haha
- JR
- Thank you received: 449
17 Nov 2011 23:46 #489037
by JR
Replied by JR on topic 83 KZ750 running issues...
It would be worth checking the valve clearances. Not as difficult as it first looks and many people neglect this. If the valves are tight when cold then when the bike heats up they expand and dont seal as well as they should. BIke cuts out and will start again easy enough from cold. You can find a shop manual here
kz.bike-night.com/
Scroll down to find "the Bible"
In general it would be good to give it a good thorough service and check also the autoadvancer under te timing cover, adjust the cam chain tension and leave the carbs until the very last - they might need cleaning and synchronising.
Good luck
Good luck
- Topper
- Thank you received: 133
18 Nov 2011 00:45 #489045
by Topper
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
Replied by Topper on topic 83 KZ750 running issues...
I was thinking fuel filter right up to the point where you said you already replaced it.
I'd check out the petcock like Dylan said. I've got a '79 and my petcock has a little sediment cup with a screen in the bottom of the petcock. If your's has something similar, take it apart and clean it.
1979 KZ750 Twin
- dylan_kz750
18 Nov 2011 02:11 #489050
by dylan_kz750
yeah, there was an old filter on there and it was real nasty, so it still could be the filter thing. i'll post updates as I progress. Thanks for everyone's help.
- wcrider62
18 Nov 2011 03:44 #489055
by wcrider62
1982 kz1100 spectre D1
Replied by wcrider62 on topic 83 KZ750 running issues...
had the problem too. would run great for 2 miles then pthh. I pulled the carbs, removed the floats and jet pins and had carb 1 and 4 with a nasty build up of what looked like air filter fibers that wouild plug the screens just before the jets. I cleaned them all -4 - out and she has been running and purring every since. not counting electrical problems, I have just finish the last of tonight. soon as tonights snow melts down in the morning going for a ride.. just cause I live in spokane dont mean I cant ride all year. gona stud my tires this weekend . keep rining
- dylan_kz750
21 Nov 2011 23:17 #489608
by dylan_kz750
I've been out of town and haven't had time to work on her yet. I just got the battery back to charge and she started right up, but not 2 minutes after start, she choked out again. Definitely think it has something to do with fuel lines/a definite carb clean. I promise no more posts until I'm done cleaning her up a little!
- TeK9iNe
- What did you do!?!
- Thank you received: 28
21 Nov 2011 23:27 #489612
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic 83 KZ750 running issues...
Make sure to seal everything from airbox/filters to exhaust tip - no air leaks.
Good luck.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- dylan_kz750
21 Nov 2011 23:29 #489613
by dylan_kz750
while carbs are off? or in general?
