76kz900a carb question
- Rocky
14 Nov 2011 01:42 - 14 Nov 2011 01:47 #488394
by Rocky
76kz900a carb question was created by Rocky
Hi, how do i know what type of mykuni carb i have?How do do i know if is a 26 or 28?
Last edit: 14 Nov 2011 01:47 by Rocky.
- Boostable
- Thank you received: 13
14 Nov 2011 01:51 #488396
by Boostable
~Jack
1982 KZ1000 J2 ~ Project (Street Fighter - Project Section)
1976 KZ900 - Daily Rider
Replied by Boostable on topic 76kz900a carb question
Are they original? (26) Have you measured them?
~Jack
- Rocky
14 Nov 2011 01:52 #488397
by Rocky
Replied by Rocky on topic 76kz900a carb question
no because i dont even know how to do that.
- Thank you received: 2098
14 Nov 2011 01:53 #488398
by Patton
Replied by Patton on topic 76kz900a carb question
Measure diameter of the bore on the engine side.
- Rocky
14 Nov 2011 01:55 #488399
by Rocky
ok ill do that thanks.
14 Nov 2011 02:02 #488400
by Patton
If necessary, may cut a narrow strip of thin cardboard 28mm long and another strip 26mm long, and see which strip fits lengthwise inside the bore.
Might not be an exact measurement, but should be close enough to distinguish between 26mm and 28mm carbs.
