83 kaw750 k1ltd belt
- locolobo
11 Nov 2011 15:25 - 11 Nov 2011 15:28 #488057
by locolobo
locolobo
83 kaw750 k1ltd belt was created by locolobo
just wired up bike...everything there is fine....when my bike fired up it spit,sputtered,backfired and would cut off...and had a terrible time restarting it...grinding and churnin.....
im going to reset floats on carbs as i mite not have done it right the first time...when i use the clear tube method...do i turn the petcock off to keep from refilling the bowls while i adjust the floats? mikuni 38....i forgot to mention that the airbox has been replaced with k&n filters...straight pipes and the proper jests were installed ....this was done by pro street cycles in richmond,va.....ran great all last summer and part of this summer...left carb started flooding out on the way back from lil sturgis in md....but that was due to trash in carbs...has been rectified...
thanx in advance
peace
doug
thanx in advance
peace
doug
locolobo
Last edit: 11 Nov 2011 15:28 by locolobo. Reason: left out some info
- Rainman
- and a little Kaw shall lead them
- Thank you received: 75
11 Nov 2011 15:29 #488058
by Rainman
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
Replied by Rainman on topic 83 kaw750 k1ltd belt
Yes, shut off fuel and drain bowl before removing.
Good Luck,
Jim
Good Luck,
Jim
Jim
Quincy,IL
The following user(s) said Thank You: locolobo
- locolobo
13 Nov 2011 06:16 #488277
by locolobo
locolobo
Replied by locolobo on topic 83 kaw750 k1ltd belt
mikuni 34s my bad....finished adjusting floats today...will fire up tomoro and see what happens....
thanx
thanx
locolobo
