KZ440 carb hookups
03 Nov 2011 22:52 #486913 by jordanka16
KZ440 carb hookups was created by jordanka16
I'm in the process of tuning up my 81 KZ440 D2 LTD. When I was removing the gas tank I noticed that there seems to be 2 hoses running towards the petcock. One was hooked up to it, and runs to the middle of the carbs and I assume supplies fuel to both to both of them. The other was disconnected and runs to the right hand carb, and connects to it right before the inlet boot. There is a similar attachment point on the left hand carb, but it has a piece of solid rubber over it.
I can take a picture of it if need be, but I was wondering if someone could tell me what these hoses are supposed to go to, maybe someone has a picture of how all the hoses are supposed to be hooked up to the petcock? Thanks for any help.
'81 KZ440 LTD
03 Nov 2011 22:59 #486914 by Nebr_Rex
Replied by Nebr_Rex on topic KZ440 carb hookups
Look at your petcock.
It should have 2 nipples,1 for to supply fuel to the carbs and the other to the vacume port.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
03 Nov 2011 23:20 #486921 by jordanka16
Replied by jordanka16 on topic KZ440 carb hookups
Nebr_Rex wrote: Look at your petcock.
It does, though before I removed the gas tank the vacuum nipple was not connected to anything. When I put it back together should I hook up the one hose on the right carb to the vacuum nipple and leave the other carb plugged? Or should I get a 3 way connector and hook them both up?
'81 KZ440 LTD
04 Nov 2011 09:04 #486954 by Nebr_Rex
just 1
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
