1980 KZ440B Carb Leaking Gas
- pjed
1976 KZ400 D3
2008 Kawasaki Ninja 250 (sold)
2005 Kawasaki ZX6RR (sold)
2013 Harley Davidson 883 Iron
- Thank you received: 2098
pjed wrote: Ran into an issue with my 1980 KZ440B this weekend. I got the bike fired up and lo and behold, one of the overflow hoses at the bottom of the carb started to just pour out gas. My carb knowledge is very limted. I think this could be a stuck float but wanted see if it could possibly be a petcock issue. This is one of those that doesn't have an off position and has been leaking very slowly out the bottom but that it. Could something have happened to it to cause the leak out of the carb when runnning? Rode the bike 2 weeks ago without issue. Thanks in advance!
With engine running at idle, try rapping smartly against the float bowl with a plastic hammer or large screw driver handle, which sometimes allows the float needle to re-set in the seat orifice.
Could also try running some SeaFoam in the fuel to hopefully clear the float valve.
If carb dis-assembly becomes necessary to clean and/or replace the float valves, be sure to also check the slim brass overflow tube inside the float bowl to determine whether it might be cracked.
- pjed
1976 KZ400 D3
Click > www.z1enterprises.com/detail.aspx?ID=293
- clutch
- I wish I had a tad more patience to do it better!
- Thank you received: 12
Patton wrote: If not already fitted, would install an aftermarket inline fuel filter, available at most bike shops and also at Z1E.
+1 Those filters are a must to help keep your carbs clean and running properly
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
