Jet Size
- Yowman
01 Nov 2011 11:08 #486468
by Yowman
Original owner of a stock, 1977 KZ1000-LTD
Jet Size was created by Yowman
Does anybody know what size jets I should be running on my '77 KZ1000-LTD, I live in Northern Nevada at 4600 feet above sea level.
- Motor Head
- Thank you received: 391
04 Nov 2011 10:48 - 04 Nov 2011 12:20 #486968
by Motor Head
Replied by Motor Head on topic Jet Size
Stock sizes, then take plug and mileage readings. Before changing jet sizes you should make sure of all the important stuff. Good Spark/ proper Ignition timing, Compression, valve clearances, clean Air filter, clean carbs all circuits, proper fuel levels, No vacuum leaks, proper function of Air Valve or blocked off.
Jetting is last basically.
Oh and I left out Carb Sync, bu that is after all the other, but before Jetting, still last.
Last edit: 04 Nov 2011 12:20 by Motor Head.
- Yowman
04 Nov 2011 10:57 #486973
by Yowman
Replied by Yowman on topic Jet Size
Thanks for the info...
- jms3257
- Thank you received: 1
08 Nov 2011 12:52 #487599
by jms3257
1980 KZ1000 LTD
Been away from riding for way too long, enjoying the journey back.
Replied by jms3257 on topic Jet Size
I purchased my bike from California Basically just above Sea Level and am living in New Mexico at 5000 ft MSL. What I was able to find out was go 1 jet size leaner for every 2000 ft you increase, or reverse that if you are going to a lower altitude. However I found that the altitude really didn’t make that much difference, just do like Motor Head suggested. I would just add however, when making jet changes just do 1 thing at a time, example don’t change pilot jet and main jet at the same time, it doesn’t correct your problem then you don’t know which one to reverse.
Jim:
Jim:
1980 KZ1000 LTD
