cant believe i did this
31 Oct 2011 18:53 #486344 by locolobo
cant believe i did this was created by locolobo
ok i was setting the float levels on my carbs....83 kz750 k1 kaw....anyway i had too much gas in the bowl so i poured into my tank and lo and behold my valve needle decided to go in my tank to....not smart......bipolar...gets me everytime....lol.....
how in the heck would you go about gettin the damn thing out.....other than cutting into the tank....man im screwed....what an a..
thanx guys......man im embarassed but hey if u dont screw up and learn than ull always be a screwup....
locolobo
  • Motor Head
31 Oct 2011 18:56 #486345 by Motor Head
Replied by Motor Head on topic cant believe i did this
Check one of the others, but it should be magnetic. Magnet on a stick will get it out.
31 Oct 2011 19:23 - 18 Feb 2013 18:02 #486352 by martin_csr
Replied by martin_csr on topic -
Last edit: 18 Feb 2013 18:02 by martin_csr.
31 Oct 2011 21:03 #486371 by 650ed
Replied by 650ed on topic cant believe i did this
If a magnet doesn't get it you can drain the tank; then remove the tank, turn it upside down, and shake the needle out the filler hole. Ed
31 Oct 2011 21:42 #486379 by roy-b-boy-b
Replied by roy-b-boy-b on topic cant believe i did this
:laugh:
I'm not laughing at you but with you. If you don't learn a sence of humor early you will go nuts if you screw up as much as I do.
I can remove that needle with a flexable magnet in fifty tries. ;) Roy
The following user(s) said Thank You: locolobo
01 Nov 2011 04:00 #486435 by locolobo
Replied by locolobo on topic cant believe i did this
i think ill go with the magnet...thanx guys...lol....
locolobo
01 Nov 2011 05:55 #486439 by wayno
Replied by wayno on topic cant believe i did this
mate, drain the tank, remove the tank then SHAKE THE NEEDLE OUT!Dont do it again.wayno :angry:
