81 KZ440 air filter
- jordanka16
26 Oct 2011 23:07 #485536
by jordanka16
'81 KZ440 LTD
81 KZ440 air filter was created by jordanka16
I recently purchased an 81 KZ440 D2 LTD that is missing it's factory flip up air filter. Right now it just has a piece of foam clamped to the air box (not sure if that's what it's actually called).
I am wondering if I should just switch to pod filters, which I can easily order at my local motorcycle store, or keep searching for a factory one. I have already searched everywhere I can think of, ebay, all different parts places, and have been unable to find one. So any leads on where one might be would be greatly appreciated. Thanks.
'81 KZ440 LTD
- Killman
- Now with 99% more ducks
- Thank you received: 12
27 Oct 2011 03:20 #485572
by Killman
1983 kz440 ltd
Quack
Replied by Killman on topic 81 KZ440 air filter
Just so happens I have a spare. PM me, and maybe we can work something out.
1983 kz440 ltd
Quack
The following user(s) said Thank You: jordanka16
- jordanka16
27 Oct 2011 20:29 #485686
by jordanka16
'81 KZ440 LTD
Replied by jordanka16 on topic 81 KZ440 air filter
Thanks Killman, and I've sent you a PM.
On a side note, the bike starts fairly easy. It takes a few cranks with the choke all the way on when it's cold, but it does start up. It doesn't run very well until it's warmed up for several minutes though, and it still pops and sputters sometimes in the low end. Would the factory air filter fix this? Or is it something else?
'81 KZ440 LTD
- Thank you received: 1656
28 Oct 2011 09:41 - 18 Feb 2013 17:55 #485765
by martin_csr
Last edit: 18 Feb 2013 17:55 by martin_csr.
- Killman
28 Oct 2011 16:39 #485796
by Killman
1983 kz440 ltd
Quack
Not sure if you're checking your PM's. Hopefully you'll see this.
1983 kz440 ltd
Quack
- jordanka16
28 Oct 2011 17:34 #485803
by jordanka16
'81 KZ440 LTD
Ahh, I'm used to getting email alerts when I have new PMs.
I got your PM and I replied Killman, and I got yours too martin. I am very hopeful that the stock filter will solve the running problems the bike has.
'81 KZ440 LTD
