Vapour Blasting, Before & After (image heavy)
- 750steve
26 Oct 2011 19:13 #485500
by 750steve
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
Vapour Blasting, Before & After (image heavy) was created by 750steve
I heard good things about this process so i send some carbs to get done, best £40 i spent so far, i can't believe how good they look now!
Just bought a replacement screw kit to finish them off properly
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
- Motor Head
- Thank you received: 391
26 Oct 2011 19:42 #485504
by Motor Head
Replied by Motor Head on topic Vapour Blasting, Before & After (image heavy)
Those definitely cleaned up nicely. Hope it all turns out good for you.
- 750steve
26 Oct 2011 19:52 #485508
by 750steve
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
Replied by 750steve on topic Vapour Blasting, Before & After (image heavy)
Me too, should be interesting anyway! I've upped the pilots to 50 & mains to 135 but thats a starting point. The carbs needed a couple of 'O' Rings for the emulsion tubes & washers/seals for the needle jet carrier (dont know the specific name). I also noticed that the needle clip was in position 4 so i moved it back to 3. I'm going to set the float level at the weekend as 1 carb needed a new float. What liquid should i use to set them?, the carbs are off the bike obviously & i don't really want to be sniffing petrol (gas) fumes all day!
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
- Motor Head
26 Oct 2011 20:05 #485509
by Motor Head
You can use water to start with, get them set, then just double check with Petrol.
With the Pod's you will want the Needle clip 1 position rich, and not in the center/ stock clip position. Don't forget to set the Butterflies so they are the same opening. This is part of your Bench set-up.
The following user(s) said Thank You: 750steve
- 750steve
26 Oct 2011 20:10 #485510
by 750steve
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
Butterflies have been checked & are ok. Thank you for the needle clip advice for the pods, thats the 1st time i've seen anyone mention it & believe me i did search.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
- Thank you received: 1656
27 Oct 2011 10:33 - 15 Feb 2013 11:57 #485602
by martin_csr
Replied by martin_csr on topic Electroless Nickel Plating info link nickelz
Someone here on KZR had his done in an electroless nickel coating. I think it takes a bit of work, though.
Painting carbs? ... scroll down for the pics.
Electroless Nickel Plating info link nickelz platingz
Last edit: 15 Feb 2013 11:57 by martin_csr.
