clear tube
24 Oct 2011 22:31 #485147 by locolobo
clear tube was created by locolobo
ok...on the clear tube adjustment theory....what exactly are we looking for...i read saw it and dont understand it....how do you knw when there is too much gas and not enuff....if i hook up the clear tube to the drain hole what or how much gas should i show...how would you adjust floats using this method...maybe im a dumb ass but i just aint grasping the theory...sorry...
locolobo
locolobo
  • Motor Head
25 Oct 2011 00:20 - 25 Oct 2011 00:21 #485182 by Motor Head
Replied by Motor Head on topic clear tube
See if this Video will help you understand how to check.
Do this before any Carb adjustments.
Last edit: 25 Oct 2011 00:21 by Motor Head.
The following user(s) said Thank You: locolobo
25 Oct 2011 09:36 - 25 Oct 2011 09:38 #485247 by KZJOE900
Replied by KZJOE900 on topic clear tube
Here is another video similar to what motorhead posted. But on my KZ carbs, which you will be more familiar with and in HD.
I use two methods of checking. But the clear tube method is shown. If any one of the levels are off, you will take the float bowl off and then the float itself off. Then adjust/bend in very small increments the tab on the float bowl. Please refer to your service manual to explain this adjustment. Afterwards, check with the clear tube method again.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: 25 Oct 2011 09:38 by KZJOE900.
25 Oct 2011 11:26 - 18 Feb 2013 17:52 #485258 by martin_csr
Replied by martin_csr on topic -
Last edit: 18 Feb 2013 17:52 by martin_csr.
