gas leaking
23 Oct 2011 22:06 #484965 by pimpstic
gas leaking was created by pimpstic
I just had my carbs rebuilt by a professional shop. I didn't even the bike back for one day and its already leaking gas from the tube shown in the pic
78 KZ1000 LTD
YOUR NOT RIDE'N UNLESS YOUR KZ RIDE'N
  • Motor Head
24 Oct 2011 09:43 #485029 by Motor Head
Replied by Motor Head on topic gas leaking
Well your pictures aren't very clear, out of focus. But if your talking about the clear line with the white Tee, that looks to be the Fuel line from the fuel tank down to your Carb's. I see there are no clamps on the lines, while sometimes this works fine, It looks like you need some. Get some Spring clamps for your fuel line size, maybe 1/4", and put those on. The only other thing I can think of on these lines would be if they are going to hold up to today"s gas. Ethonal could be causing your lines to get soft, and deteriorate, causing the loose fit at the barbed fittings. Nice having clear line, but some of the lines won't hold up with today's S**t gas.
The following user(s) said Thank You: pimpstic
24 Oct 2011 15:18 #485073 by pimpstic
Replied by pimpstic on topic gas leaking
ok thanks for the advice
78 KZ1000 LTD
24 Oct 2011 15:36 - 24 Oct 2011 15:36 #485074 by bountyhunter
Replied by bountyhunter on topic gas leaking
The clear fuel lines are crap. They actually harden and crack with age. If you are leaking turn the petcock off each time you park it.
Last edit: 24 Oct 2011 15:36 by bountyhunter.
