i am stuck
17 Oct 2011 17:45 #483813 by silentchris
i am stuck was created by silentchris
tore my carbs down cleaned them up replaced float needles and primary jets same size as the gross ones that came out everything is flowing free except one float bowl has a clog in the starting circuit i cant get to come free. both my #1 and #3 carbs leak from the overflows. the bike started and ran idled at 5k with the chocke on i backed the idle down to 2k and it idles at 1k with the choke off. the problem is its really hard to start the bike. it has pods and a 4/1 header any ideas for clearing that starting circuit and the right float settings would be much appreciated thanks guys
Speed is only a question of money. How fast do you wanna go?
1978 kz1000 ltd
Hailing from the wild suburbs of our nations capital
17 Oct 2011 17:55 #483817 by Patton
Replied by Patton on topic i am stuck
:unsure: Style carbs? :unsure:
17 Oct 2011 20:06 #483835 by silentchris
Replied by silentchris on topic i am stuck
Woops carb style may bea we bit important 1978 kz1000 ltd with stock vm26ss o n it
1978 kz1000 ltd
18 Oct 2011 03:16 #483901 by KZJOE900
Replied by KZJOE900 on topic i am stuck
Just cleaned a starting circuit on one of my VM26's today. Just used an appropriate gauge wire to from the top. And then bent the wire at an angle to clean from the bottom. Followed this by some shots of carburetor cleaner to confirm it was unclogged.
Check your float level using the clear tube method. Adjust and retest as necessary. Once the floats levels are adjusted, if you still have a leak from the overflow on #1 and #3, you may want to check the overflow tubes on the two units to make sure they don't have any hairline cracks.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • clutch
  • I wish I had a tad more patience to do it better!
18 Oct 2011 03:19 #483902 by clutch
Replied by clutch on topic i am stuck
KZJOE900 wrote: Just cleaned a starting circuit on one of my VM26's today. Just used an appropriate gauge wire to from the top. And then bent the wire at an angle to clean from the bottom. Followed this by some shots of carburetor cleaner to confirm it was unclogged.
Good advice! That's they way to go for sure :)
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
