84 zn700 vacuum
  • scirocco17
  • scirocco17's Avatar Topic Author
84 zn700 vacuum
18 May 2006 16:55
#48281
all the vacuum lines are off, does anyone have a diagram co i can hook up these carbs correctly?
  • agawam
  • agawam's Avatar
Re: 84 zn700 vacuum
18 May 2006 19:35
#48336
there are 4 vacume ports going from left to right #1 and #4 get connected to the AIR system(valve cover) #2 goes to the petcock #3 gets plugged or capped
  • scirocco17
Re: 84 zn700 vacuum
18 May 2006 19:56
#48343
Thanks, I'm going to run it like that possibly tonight when I get off of work (11pm) which the wife won't like. Or tomorrow, I'll let you know how it works out for me. I still need to get some spark though. Thanks Again! B)
Post edited by: scirocco17, at: 2006/05/19 10:54
  • wiredgeorge
  • wiredgeorge's Avatar
Re: 84 zn700 vacuum
19 May 2006 06:52
#48433
agawam is correct but to clarify, 1&4 go to a tee fitting which has a hose coming off it and THAT hose goes into the vacuum switch which operates the reed valves (inside the valve cover).
  • scirocco17
Re: 84 zn700 vacuum
19 May 2006 07:49
#48454
OK I went out early this morning excited to play motorcycles and I discovered that I left out a few things. There are more than 4 hose nipples on the carbs. There are actually 7. so I snapped some pics and numbered them up. I'm not the sharpest crayon in the box sometimes, but hopefully theres no way this can go wrong and all hoses will be accounted for! Yay!
Im new here and I guess you cant upload pics to the site so I have to host them on my webshots which means you have to click below to see them, sorry guys.
Photo#1 community.webshots.com/photo/548933797/2...33350059435507IuZLTz
Photo#2
community.webshots.com/photo/548933797/2...54660059435507DpsTli
So there they are, Kinda. Please tell me where these lines go #'s 1-7. Thanks!!
Post edited by: scirocco17, at: 2006/05/19 10:52
  • scirocco17
Re: 84 zn700 vacuum
19 May 2006 07:57
#48457
OK so i think i got them to work, the pictures, but they are scattered throughout the post now. I'm getting the hang of it though....
I'm pretty sure #6 is the fuel line. Am I right?
Post edited by: scirocco17, at: 2006/05/19 10:59
  • wiredgeorge
Re: 84 zn700 vacuum
19 May 2006 08:10
#48468
If you go to my web site, you will find some pics that will help you hook up your carburetors. 1-4 ARE VACCUM ports. I have already told you how to hook these up.
  • scirocco17
Re: 84 zn700 vacuum
19 May 2006 09:25
#48496
Sweet your website was CRAZY helpful and explained all that carb stuff really well! THANKS A MILLION:cheer:
  • agawam
  • agawam's Avatar
Re: 84 zn700 vacuum
19 May 2006 21:27
#48630
your #s 5 & 7 are vents for the fuel bowls #6 is fuel inlet
Post edited by: agawam, at: 2006/05/20 00:28
