Which Needle Valves ???
- Tulsa74136
06 Oct 2011 23:39 - 06 Oct 2011 23:41 #481816
by Tulsa74136
1980 KZ1000 - B4 LTD (12/79 Mfd Date)
PODs, Kerker Header, Mikuni 29mm Smoothbores
Vetter Windjammer Fairing & Trunk
1981 KZ1000 - M1 CSR (03/81 Mfd Date)
All Stock except for PODs
1981 Yamaha XJ550H Maxim
All Stock
1977 KZ400 - D4 (2012/13 Winter Project) SOLD
Which Needle Valves ??? was created by Tulsa74136
Looking to rebuild my Mikuni Smoothbore 29s. When looking for parts I am given a choice of a 2.5 or a 2.8 Needle Valve Assy. Anyone know which one I should choose ? Stock engine as far as I know, running the 29s, PODs and a 4-into-1 header. Any recommendations on where to buy parts for the Mikunis, not having any luck with anyone offering a rebuild kit. Thanks in advance for your help.
Todd
Todd
All Stock
Last edit: 06 Oct 2011 23:41 by Tulsa74136. Reason: left an item out from the listing
- moneypit
- Thank you received: 35
06 Oct 2011 23:59 - 07 Oct 2011 00:01 #481820
by moneypit
2-76 kz900
St Paul MN
Replied by moneypit on topic Which Needle Valves ???
Have you tried Z1 enterprises, they have alot of the smoothbore stuff youll need, I beleive 2.5 is standard
www.z1enterprises.com/Mikuni-Needle-Valve-Assembly--25-74.aspx
2-76 kz900
St Paul MN
Last edit: 07 Oct 2011 00:01 by moneypit. Reason: spelling
The following user(s) said Thank You: Tulsa74136
- Thank you received: 2098
07 Oct 2011 00:32 #481824
by Patton
Replied by Patton on topic Which Needle Valves ???
Z1 Enterprises offers some parts for Mikuni smoothborecarbs.
Click here > www.z1enterprises.com/catalog.aspx?pid=KPCF3
- Jeff.Saunders
07 Oct 2011 09:25 #481851
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic Which Needle Valves ???
There are no 'prebuilt' rebuild kits. Mikuni sold these carbs for too many different applications to have a 'one size fits all' kit.
We do have all the typical serviceable parts in stock. Most times the float bowl gaskets and float needle valve assemblies are all you need - although if the carbs have been sitting a long time you may have to replace the 12 o-rings on the fuel T and fuel rails.
Z1 Ent on Facebook,
- Tulsa74136
09 Oct 2011 22:17 #482218
by Tulsa74136
All Stock
Replied by Tulsa74136 on topic Which Needle Valves ???
I looked at the parts you have available for the Smoothbore Mikuni 29s on your website. You have a 2.5 needle valve assy (seat, washer & needle). Other websites have listed a 2.8 needle valve assy in addition to a 2.5 . Can you tell me the difference in the 2.5 vs 2.8 ? As far as I know, my engine is stock, other than the Mikuni 29s & a 4 into 1 header. Will the 2.5 work for me or do I need a 2.8 ?? Thanks for any help you can offer.
Todd
Todd
All Stock
- Motor Head
- Thank you received: 391
09 Oct 2011 23:06 #482229
by Motor Head
Replied by Motor Head on topic Which Needle Valves ???
If your engine is stock, then a larger float needle valve should not be needed. If you look at yours there will be a stamping of the size, most likely 2.5
There is a direct correlation between jet sizes and the size of the float valve. then it is also different if you had a pressure feed system.
I think you would order whats in your carbs already, 2.5
- Jeff.Saunders
11 Oct 2011 08:46 #482515
by Jeff.Saunders
Z1 Ent on Facebook,
We don't list the 2.8 n/v as there's really no application for them in 29mm smoothbores. 2.5 is the hole size in the seat that allows fuel into the float bowl. Anything up to 1100cc the 2.5 opening is the best choice. And once you get over 1100cc the 29mm smoothbores are too small anyway...
Z1 Ent on Facebook,
The following user(s) said Thank You: metrorollah, Tulsa74136
