- Thank you received: 3
KZ carbs on a ZX
- RobK
05 Oct 2011 14:45 #481515
by RobK
My mule's got the funny idea you're laughin' at him. Now if you apologize like I know you're gonna...
KZ carbs on a ZX was created by RobK
Hey Y'all,
Haven't posted in a while because I've been messing with a couple of Yamaha XTs, but working on a new project and I have a (potentially stupid) question.
I recently picked up a '90 ZX7 that has freshly rebuilt '87 GPX (ZX) 750 motor.
The heads on the two bikes are at a different angle (the ZX leans more forward), so as a result there is much less space for the airbox and neither stocker will fit.
These carbs being CVs mean that pods probably aren't ideal. So my next thought is to go with flatsides so I could with pods. Good idea, but my wallet isn't up for the task for $500+ for a set of used Mikunis off Fleabay.
Then I started wondering about the two banks of carbs that I have for the ZX900 project, one set of 26mm Mikunis (the stock units) and another set that came with the bike, a set of 28s that likely came from a kz650 or 750.
I have to admit, my knowledge of carbs is fledgling, so I'm not sure how stupid this idea is. There is clearly a difference in manifold size which could be an issue, but how much I don't know. Is this a deal killer?
Any other reason why I can't put the carbs from the KZ on the ZX, (other than spacing)?
A note here, the ZX will get a full treatment later on I'm just looking to build up a daily rider so I can get back to the KZ. Optimal performance can be worked on later, I'm just looking for something that will go fast enough to keep life interesting. :evil:
Any body wanna chime in and let me know if this is a half-baked scheme?
Thanks.
RK
Thanks.
RK
- Thank you received: 1656
05 Oct 2011 17:39 - 15 Feb 2013 11:41 #481544
by martin_csr
Last edit: 15 Feb 2013 11:41 by martin_csr.
- jeffasaki
- Thank you received: 44
05 Oct 2011 17:50 #481546
by jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
Replied by jeffasaki on topic KZ carbs on a ZX
the angle is too steep on the zx
the floats wont work properly
how ever i do have a set of carbs off a zx 600
that have the correct float bowl angle
i can go dig em out if you want
let me know
Jeff
let me know
Jeff
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- RobK
05 Oct 2011 18:15 #481552
by RobK
Replied by RobK on topic KZ carbs on a ZX
Aren't zx600 carbs also CVs?
Did you mean that the float bowls need to be level?
Here's a pic of the current set up, the carbs are pretty close to vertical, (especially as the rear wheel is about 3-4 inches off the deck).
- steell
06 Oct 2011 01:25 #481631
by steell
Replied by steell on topic KZ carbs on a ZX
Look at the carbs on the bike behind it, they are not tilted as bad but still have slanted bowls on them.
- RobK
06 Oct 2011 03:26 #481639
by RobK
Yeah - I've just had some time to get into the bike a bit, and having seen how out the spacing really is and the condition of the 28s, I'm gonna look at another solution.
I'm gonna do a little more research on alternatives to CV (flat and round slide I'm presuming) and there's always the possibility of making an airbox out of fiberglass.
Thanks much all for the feedback.
