float bowl level
- 78kz400
04 Oct 2011 15:50 #481345
by 78kz400
float bowl level was created by 78kz400
How important is the level of fuel in the bowl? Specs say 2mm from the top of the carb body where the bowl meet the body to the hight of fuel in the bowl. What would be some probelms associated with either to high or to low of levels? The carb is a keihin cv32
- Motor Head
- Thank you received: 391
04 Oct 2011 19:52 #481369
by Motor Head
Replied by Motor Head on topic float bowl level
Fuel level is Very Important, and with Multiple Carbs they all should be the same. If Low it will cause a lean condition, and High a Rich condition, possibly even flooding if high enough. Basically it will effect how easy the fuel will be lifted through the Jets from the Fuel Bowl. High= easy, Low= harder.
Does this help?
Does this help?
- P21
- Thank you received: 34
04 Oct 2011 20:36 #481381
by P21
how important VERY
here is my KZ 1000 carbs this set-up you MUST have carbs LEVEL first (off bike)
Kawasaki KZ 1000 Police (2002) P21
Replied by P21 on topic float bowl level
Attachment CARBFUELLEVEL8-27-11027.jpg not found
Attachment CARBFUELLEVEL8-27-11005.jpg not found
how important VERY
- JR
- Thank you received: 449
05 Oct 2011 00:41 - 05 Oct 2011 00:42 #481419
by JR
Replied by JR on topic float bowl level
I could not believe how inportant it was until I did it.
I checked using a ruler. I noted the measurements. I removed the carbs, turned them upside down, measured the float height, did the math and adjusted the float height to give me the calculated correct fuel level.
The difference between having the correct to spec fuel level versus something that was eyeballed and innacurate was amazing !!! I could feel the difference beforeI reached the end of my one car length driveway.
Go for it
Go for it
Last edit: 05 Oct 2011 00:42 by JR.
- bountyhunter
- Thank you received: 337
05 Oct 2011 02:39 - 05 Oct 2011 02:40 #481439
by bountyhunter
Replied by bountyhunter on topic float bowl level
Super important. My right carb was one mm higher than the left and it made it spit and sputter at idle. Put it up on the center stand to make sure they are level.
Last edit: 05 Oct 2011 02:40 by bountyhunter.
- 78kz400
05 Oct 2011 12:30 #481495
by 78kz400
Replied by 78kz400 on topic float bowl level
Thanks a ton for the feedback and photos, i will make sure mine are at the perfect level (let the good times roll)
