- Thank you received: 34
PVC Airbox w/ pods
- eddiem
- KZR FLAG RELAY CARRIER #63
01 Oct 2011 23:43 #480869
by eddiem
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
Replied by eddiem on topic PVC Airbox w/ pods
this pic was posted on here a while back thought it was pretty cool
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
- wireman
- Thank you received: 299
02 Oct 2011 00:09 #480873
by wireman
Replied by wireman on topic PVC Airbox w/ pods
yeah i liked it also it uses a single pod filter out the back side of it,carefull though he'll accuse you of stealing his buddys ideas to make cheap copies of it! :sick: :whistle:
- roccbottom
- 1984 gpz1100, 1995 kz1000p
02 Oct 2011 00:45 #480878
by roccbottom
Replied by roccbottom on topic PVC Airbox w/ pods
Great use of off the shelf items, must be true about necessity being the mother of invention..
- Old Man Rock
- Thank you received: 225
02 Oct 2011 10:40 #480919
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic PVC Airbox w/ pods
Is the ABC 90's going to clear the frame tubing?
Any images of this installed/in-place?
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- kcornell6
- Thank you received: 1
02 Oct 2011 14:13 #480944
by kcornell6
96' KZ1000P Bobbed
81 GS850L
Replied by kcornell6 on topic PVC Airbox w/ pods
Hey all,
Glad to see there's some interest about this idea. To answer some questions/thoughts.
I do still need to buy filters. Not sure which ones I'm going to go with at this point though. The point of using the piping instead of straight pods is for that little bit of back pressure; so jetting MAY not be needed. But we'll see when that time comes.
If things work out with this, I also want to make it into a metal piece. Wouldn't be that hard since the "prototype" is already there and set up.
I'm not with the motorcycle at this time, probably wont get back to the shop until tomorrow or something this coming week. I'll be sure to take some pics of installation. Just a little worried about clearing the frame, but there might be a way around that.
Always looking for different and cheaper ways to build everything as long as it gets the job done the right way. My build is located HERE
V/R
Kev
V/R
Kev
96' KZ1000P Bobbed
81 GS850L
- kcornell6
02 Oct 2011 14:14 #480945
by kcornell6
96' KZ1000P Bobbed
81 GS850L
I truthfully didn't see that post. Have't been on here long, but thats a really nice system he's got goin there. Were there any reports about how it turned out for him?
V/R
Kev
V/R
Kev
96' KZ1000P Bobbed
81 GS850L
- kcornell6
06 Oct 2011 15:08 #481723
by kcornell6
96' KZ1000P Bobbed
81 GS850L
Finally got back to the shop. Got the "airbox" fitted and took some pics you guys wanted to see.
Had to actually cut them down about 3/4in so they would fit horizontally. Was in a little rush, so they aren't correctly seated in the boots. But you guys get the main idea.
Once I buy a filter, you wont be able to see the innards of whats happening really. Happy with how they came out. Maybe time to get them into a metal piping setup...
V/R
Kev
V/R
Kev
96' KZ1000P Bobbed
81 GS850L
- apbling
- Thank you received: 12
07 Oct 2011 12:49 #481865
by apbling
Replied by apbling on topic PVC Airbox w/ pods
Maybe I missed this comment already, but the way it's plumbed, wouldn't carbs 1 and 4 get more air than their mate, 2 and 3? If you follow the airpath, it's less resistance for it to go into 1 or 4 instead of 2 and 3. Seeing as the diameter of the pipe is large, it might not make a difference, but I'm thinking your outter carbs might see more air than the inner ones. Would maybe having a piece of pipe between 2 and 3 tieing everything together help alleviate this?
- kcornell6
07 Oct 2011 13:15 #481872
by kcornell6
96' KZ1000P Bobbed
81 GS850L
You bring up a great point. I have thought about this problem/ possible solutions. I am going to wait untill I get the ride totally running and test it. If the plug chop tells me 1 and 4 are more lean, I'll try to adjust or, or maybe make that inner tube connecting all 4. It's a a new idea so just gonna take a little time.
V/R
Kev
V/R
Kev
96' KZ1000P Bobbed
81 GS850L
- peter1958
- Banned
- Thank you received: 198
07 Oct 2011 13:27 #481877
by peter1958
Replied by peter1958 on topic PVC Airbox w/ pods
When I run my kz1000 with kns on and its windy its a pain. Cant see how this is going too work with filters out the side in the air.
- apbling
07 Oct 2011 15:06 #481882
by apbling
Peter has a good point too... the faster you go, the more air you will be getting into them... I wonder how the hell harley's do it when they have those crazy intakes - oh wait, they don't got over 45...
- Kidkawie
- I bleed premix
- Thank you received: 245
07 Oct 2011 15:59 #481888
by Kidkawie
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Replied by Kidkawie on topic PVC Airbox w/ pods
Most HD or side draft carbs have a wind deflector.
1975 Z1 900
2004 KX125
