Pingel ?
30 Sep 2011 22:25 #480688 by mvent
Pingel ? was created by mvent
Fired up bike yesterday first time since assembly, not liking the original vacuum petcock, does the Pingel sold by Z1 Ent bolt directly on 78 KZ1000 with stock carbs? No fitment mods for it to work?
Thanks
Mike
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
  • trianglelaguna
30 Sep 2011 23:11 - 30 Sep 2011 23:13 #480699 by trianglelaguna
Replied by trianglelaguna on topic Pingel ?
call them....tell them how many fuel lines in you use now and tell them whether it is a spin on or bolt on assembly you have now and they will hook a brotha up
oh and for starts i dont know many 78 kz1000 that have vacuum...but im no expert
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Last edit: 30 Sep 2011 23:13 by trianglelaguna.
  • DoubleDub
  • Visitor
30 Sep 2011 23:12 #480700 by DoubleDub
Replied by DoubleDub on topic Pingel ?
trianglelaguna wrote: ...but im no expert
Says the expert.
  • ready2ryde1985
  • got to love these kzs
30 Sep 2011 23:22 #480702 by ready2ryde1985
Replied by ready2ryde1985 on topic Pingel ?
I bought the pingle petcock and the adapter plate then all there was to do was enlarge the hole in the tank that the old petcock went threw.
Mount the plate then screw in the petcock add fuel line fule filter. Dont forget to turn off your new petcock or it will vapo lock and wash out your rings. In the event that you do forget. Drain your oil and change your filter I have herd these bikes can become a bom.
84 kz 700 a1
82 kz550 ltd
  • clutch
  • I wish I had a tad more patience to do it better!
30 Sep 2011 23:49 #480709 by clutch
Replied by clutch on topic Pingel ?
Since there's a post already, I was just curious if the low end "made exclusively for Z1Enterprises" has a high enough fuel flow for a kz750 e3? I know I will need an adapter plate, but I need to replace the vaccuum petcock because it leaks in prime and res positions now.
~Clutch
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
  • trianglelaguna
01 Oct 2011 00:04 #480712 by trianglelaguna
yes it is a good product i have two and they work fine
clutch wrote: Since there's a post already, I was just curious if the low end "made exclusively for Z1Enterprises" has a high enough fuel flow for a kz750 e3? I know I will need an adapter plate, but I need to replace the vaccuum petcock because it leaks in prime and res positions now.
~Clutch
1976 KZ900
2003 ZX12R
2007 FZ1000
The following user(s) said Thank You: clutch
  • clutch
01 Oct 2011 00:06 #480714 by clutch
trianglelaguna wrote: yes it is a good product i have two and they work fine
~Clutch
Cool tyvm. I had one of the old ones on my kz250 D1, and it worked well for that, but the 750 suck up gas a little quicker. I just wanted to be sure. :)
Wish List:
Z1 (need I...
01 Oct 2011 09:41 #480755 by mvent
Replied by mvent on topic Pingel ?
trianglelaguna wrote: call them....tell them how many fuel lines in you use now and tell them whether it is a spin on or bolt on assembly you have now and they will hook a brotha up
Absolutely is vacuum, stock, 2 fuel lines, 1 vacuum line, it's an A2A, maybe different from an A2 IDK.
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
  • ready2ryde1985
01 Oct 2011 10:31 - 01 Oct 2011 10:34 #480760 by ready2ryde1985
This was a good explanation of instal from gs 500 site
gstwin.com/racers_corner.htm
84 kz 700 a1
82 kz550 ltd
Last edit: 01 Oct 2011 10:34 by ready2ryde1985.
01 Oct 2011 11:33 #480762 by Old Man Rock
Replied by Old Man Rock on topic Pingel ?
I'll start off with Jeff (Z1) has already replied in regards to the cheaper petcock units they sold where faulty O-ring/diaphragm or something to that effect was acknowledged... They would drip fuel into the fuel line in off position. Assumption is this has been corrected.
Same time, go with the Pingel units no doubt... Worth every dime in my book. They cost about twice the price but you do get what you pay for. Well made! ;)
OK, with that said, they do offer Power Flow Vacuum Petcocks but unknown for your model. You most likely will have to do some mod/tweaking on your tank opening. Most of their petcocks come with adapter plates.
You'll have to do the research, here's the link....
Vacuum Petcocks
Good luck let us know what you come up with...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • wireman
01 Oct 2011 11:36 #480764 by wireman
Replied by wireman on topic Pingel ?
go with the guzzler and be done with it! :woohoo:
  • trianglelaguna
01 Oct 2011 13:39 #480774 by trianglelaguna
the cheapo works fine is all im saying and the leaky deal was a sub-supplier tiny 2 cent rubber bisquit that caused the guys a ton of head aches...i ordered 2 of the lower cost,that they now have current, that do not have any issues .......and they work great....i aint saying pingel aint the greatest....i'm just saying it will flow fine and work,,,you asked
1976 KZ900
2003 ZX12R
2007 FZ1000
