Carb cleaned, new plugs, new oil, why no run?
25 Sep 2011 20:34 #479501 by Flyndrive
Replied by Flyndrive on topic Carb cleaned, new plugs, new oil, why no run?
I know on my bike I had to clean the carbs 3 or 4 times before everything was out. Also make sure you have a good fuel filter to keep any new contamination out.
Good luck!!
1980 KZ 550A1
1985 GPZ 900R
25 Sep 2011 22:54 #479554 by djesurun1
Replied by djesurun1 on topic Carb cleaned, new plugs, new oil, why no run?
Wow thanks a ton guys, those are great tutorials...I can't believe how much i missed when cleaning! Hopefully there will be a post on here soon saying its running and I'm gone! Lol. Do you guys use a Manometer to sync your carbs or do the home-made setups work just the same?
Waiting to Ride a 98' KZ1000-P
Starters out of commission...stuck on four wheels at the moment :(
My $700 project bike is on its way!
  • Motor Head
25 Sep 2011 22:55 #479555 by Motor Head
Replied by Motor Head on topic Carb cleaned, new plugs, new oil, why no run?
For sure the home made, supper sensitive and gets them synched really well. Did I mention CHEAP!!!!!!! :P
13 Oct 2011 12:39 #482934 by djesurun1
I've rebuilt that carbs and it sounds great to my untrained ears!! The pilots were all plugged pretty bad...no wonder it wouldn't run! Here is the manometer i made, splashed a good bit of marvel mystery fluid on it in the process lol. Don't laugh at my packaging tape attachment job! #2 has way too much pull even when the mixture screw is completely seated. That indicates an air leak somewhere right? How small of a hole can the diaphgrams get? I didn't notice anything when I cleaned it.
13 Oct 2011 14:56 #482958 by bountyhunter
Replied by bountyhunter on topic Carb cleaned, new plugs, new oil, why no run?
djesurun1 wrote: I've rebuilt that carbs and it sounds great to my untrained ears!! The pilots were all plugged pretty bad...no wonder it wouldn't run! Here is the manometer i made, splashed a good bit of marvel mystery fluid on it in the process lol. Don't laugh at my packaging tape attachment job! #2 has way too much pull even when the mixture screw is completely seated. That indicates an air leak somewhere right? How small of a hole can the diaphgrams get?
Mine had several tiny slits I could only see if I held them up to light.
13 Oct 2011 15:18 #482961 by djesurun1
Ok I'll start there and see if that's it.
