- Thank you received: 103
Stored bikes
- roy-b-boy-b
The crappy gas even has the fuel filters stopped up.
I pulled down a set of carbs off a CB750 and they were so bad the float needles were stuck. I had a hard time removing them. I cannot reuse them and had to find new.
I suggest to completly drain the fuel system for winter storage. Roy
- cobura
- forever 2 wheels
- Thank you received: 3
1979 KZ650B3
- roy-b-boy-b
- testarossa
- Thank you received: 82
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- T_Dub
- Thank you received: 25
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
- Thank you received: 2829
Attachment IMG_0859.JPG not found
- cobura
- forever 2 wheels
1979 KZ650B3
- Thank you received: 1656
- racer54
- Thank you received: 114
- MFolks
- Thank you received: 540
Ethanol In Gasoline Problems
Certain materials commonly used with gasoline may be incompatible with high-level ethanol blends, causing them to degrade and contaminate the fuel. Metals that have been shown to degrade over time in the presence of high-level alcohol blends include brass,(floats & jets) lead, zinc(carb bodies) and lead-based solder.
Nonmetallic materials that degrade when in contact with ethanol include natural rubber, polyurethane, cork gasket material, leather, polyvinyl chloride (PVC) polyamides, and certain thermoplastic or thermoset polymers.
On the other hand, unplated steel, nickel-plated steel, stainless steel, black iron and bronze have shown resistance to ethanol corrosion, with nonmetallic materials like reinforced fiberglass, Buna-N, Neoprene rubber, polypropylene, nitrile rubber, Viton and Teflon meeting acceptable usage standards with E85.
racer54 wrote: Damn...look at all that snow. The thought of snow is depressing...I should move down into OMR's part of the world I guess. Where do you live 650ed? That is a lot of snow there. Your bike does look fantastic! Needs a nice warm sunset behind it though! :laugh:
Thanks Cobura & Racer54 for the kind words. I'm in Maryland, and we've had a couple pretty bad snow storms the last couple years. I'm hoping this year won't be so bad. If only this "global warming" thingy would come my way I'd be happy. :woohoo: Ed
- riverroad
- 1980 1000LTD B4
- Thank you received: 7
