Engine Forum
Engine forum is a tech forum for "Engine" topics.
OH NO I THINK MESSED UP BAD!!!!
  • jamestheron
  • jamestheron's Avatar Topic Author
16 May 2006 13:44
#47768
mind you the bike sat for 5 years.
well i though it would be a good idea to change the fuel lines and filter i hooked the lines up wrong gas to the vacuum now my bike starts but bogs real bad and pops and the air cleaner box had 1 inch of gas in it i cleaned up the box but now
what should i do :(
  • Pterosaur
  • Pterosaur's Avatar
Re: OH NO I THINK MESSED UP BAD!!!!
16 May 2006 13:58
#47770
Pull the carbs and get 'em professionally cleaned.
The floats are *waaaaaaaaaaaaaay* stuck.
Sorry, mis-read the post first time.
Yeah, changing the oil ain't a bad idea either.
Amazing it even runs on 5+ year sitting carbs.
Amazing machines.
Post edited by: Pterosaur, at: 2006/05/16 17:07
  • captaincrusty51
  • captaincrusty51's Avatar
16 May 2006 13:59
#47772
You probably contaminated your oil if you flowed that much gas through everything. Before running the bike make sure you change the oil and filter.
Post edited by: captaincrusty51, at: 2006/05/16 17:00
1978 KZ650C
Keihin CR Special carbs, MAC 4 into 1, Koni Shocks, Emgo Pods
2002 ZRX1200R
Akrapovic exhaust, Teds Ignition Advance, Steering Damper, Dunlop Qualifier tires, Corbin GF/L,Rear tire hugger, Tsukigi braces
  • jamestheron
16 May 2006 14:57
#47791
I just went out and drained the oil wow smells bad of fuel and way over full I'm guessing that running it like that for the 15 min on and off resulted in the valve cover oil leak i have now :angry: boy ill tell ya i cant do nothing right:blush:
well cents i will have the cover off i should check the valve clearance now that is going to get scary
Post edited by: jamestheron, at: 2006/05/16 18:01
  • Pterosaur
16 May 2006 15:45
#47800
In my professional opinion, your best bet is to consult a *professional*.
Get with Wired George on this.
He snores specs in his sleep, and gets the most said the clearest with the fewest words. He whips off fix-it how-to's in minutes that most of us couldn't pull off with a third eye, a factory manual and a trained octopus flippin' the pages... ;)
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
17 May 2006 05:07
#47953
If you hooked the fuel line to the intake vacuum port you likely locked that piston with liquid. It would be a good idea to check for damage. A rough inspection by removing all plugs and seeing if TDC is equal for each pair of pistons is a good start.
  • jamestheron
19 May 2006 04:25
#48391
OK the valves checked out fine the plugs are Gray and some are black soot I'm thinking that's from the gas issue and not having a air cleaner wile running the bike off and on.
i think i going to do the air cleaner k&N cones where do the vacuum line go after you remove the old uncleaner box????
  • Duck
  • Duck's Avatar
19 May 2006 05:00
#48402
you need a manual
there are exploded diagrams under the 'parts category for your 79 police at buykawasaki.com useful for seeing what goes where in a pinch
send your carbs to george
i can't imagine anyone doing as much for as little as he does
i'd need twice what he charges and take 6-8 weeks to get them done plus you'd have to pay shipping to and from hawaii
