- Thank you received: 1
1977 24mm makuni needle position and bowl number?
- indianajames
18 Sep 2011 10:41 #477628
by indianajames
1977 24mm makuni needle position and bowl number? was created by indianajames
took these apart to rebuild and noticed needle position on one carb was different than the others , more hanging out when looking at them with bowls off , should i put them back this way ? this is on the accelerator pump carb. also was missing the little brass weight and ball in that carb . needle position to compensate for this ? also only numbers i could find on these carbs is on the bottoms of the bowls it is 35 thats all , does this mean anything ? lastly , white lumpy corrosion on carb inside bowls on the jet housings but not inside where jets and needle seats and float valve is , still worth rebuilding?
- indianajames
18 Sep 2011 11:44 #477633
by indianajames
Replied by indianajames on topic 1977 24mm makuni needle position and bowl numb
have i asked totally dumbass questions or is it my "naked" profile?
- indianajames
18 Sep 2011 13:00 #477646
by indianajames
thought maybe 650ed or patton might have some anwers to these questions . thanks in advance.
- indianajames
18 Sep 2011 17:08 #477682
by indianajames
hope i didn't piss anybody off. just dont know that much about these kind of carbs . when i have posted in the past , someone has always had an answer or a good guess , this is a great forum and i wouldn't jepordize this knowingly , and i have contrbuted when i could . anybody?
- Thank you received: 2098
18 Sep 2011 17:18 - 18 Sep 2011 17:19 #477683
by Patton
Replied by Patton on topic 1977 24mm makuni needle position and bowl numb
Not to worry -- profile for indianajames contains an avatar and postings.
Including information about bike year and model may elicit better responses.
And it's easy to put the information in your signature where it will automatically appear in posted messages.
When done, the signature information appears in all posts, past and future.
And may be changed as often as desired.
Imo, jet needle clips should be in the same position on every needle.
Often, stock position is the middle clip position, but this isn't universal.
Attachment addsig.jpg not found
Last edit: 18 Sep 2011 17:19 by Patton.
The following user(s) said Thank You: indianajames
- rstnick
- Thank you received: 377
18 Sep 2011 21:28 - 18 Sep 2011 21:29 #477733
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, Progressive Suspension, braced swingarm, ZRX shocks, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic 1977 KZ650 24mm mikuni needle position
Agreed, I never heard of the needles being clipped differently.
Do check that the main jets are all the same.
If the one on carb two is a different size, then maybe the PO compensated by clipping the needle differently.
Clean them up and resync them.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Last edit: 18 Sep 2011 21:29 by rstnick.
- indianajames
18 Sep 2011 22:24 #477746
by indianajames
thanks fellas , was getting worried ,did something wrong. rstnick i never thought of that ill check the jets tomorrow , and thanx patton i was thinking they should be the same. any info about the bowls having the numbers 35 on the bottom ? also im replacing the 0 rings in each carb but cant find a source for the little brass weight and ball in the bowls . tried CMSNL and Z1 , i was thinking i could cut a piece of brass tube from hobby store and fill with solder , and use a bb or a ball bearing from a bicycle neck, might just work. this bike is a 77 650 b . one more question , can these carbs work without the accelerator pump ? maybe just not as quick to respond?
- gd4now
- Denco where did you go?
- Thank you received: 445
19 Sep 2011 00:15 - 19 Sep 2011 00:26 #477775
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic 1977 24mm makuni needle position and bowl numb
First agree, that the needles should be set the same on each carb. But I do have quesiton. Is it a 77b or a 78b? IIRC the 77 did not come with accel pump carbs, but some of the 78s did. However, after 30 some years the carbs may have been changed at some point.
As to the parts you are missing, I think they are part of the accel pump rebuild kits you can purchase. However, I could be wrong about that.
I am not familar with the number on the bowl that you describe, but there should be some very small numbers stamped on the flange just below the choke lever on carb #1. The accel pump carbs should have the following stamped there;
108
4 - there may well be other numbers or letters after the 4.
This would indicate the carb assembly is part# 16001-1084. If that is the case they came stock with the following needle - 5CL16 with the clip in the 3rd slot.
As to the 650 b models frame and engine numbers see below:
1977 KZ650B1
Japan: Frame 000001-026990
Engine 000001-045147
USA: Frame 500001-508015
Engine 000001-043949
1978 KZ650B2
Japan: Frame 027501-032200
Engine 046001-057787
USA: Frame 508016-515325
1978 KZ650B2A
Japan: Frame 033501-044828
Engine 061299-090685
USA: Frame 515326-523523
Engine 061299-092000
1979 KZ650B3
Japan: Frame 046201-047350
Engine: 092001-102148
USA: Frame 523524-533520
Engine 092001-116800
108
1977 KZ650B1
1978 KZ650B2
1978 KZ650B2A
1979 KZ650B3
1977 KZ650 B1
Last edit: 19 Sep 2011 00:26 by gd4now.
