1974 z1 fuel injection?
- Doogie147
14 Sep 2011 13:14 #476676
by Doogie147
1974 z1 fuel injection? was created by Doogie147
does anyone know if there is a fuel injection kit that would work on a 1974 z1?
- MFolks
- Thank you received: 540
14 Sep 2011 16:37 #476739
by MFolks
Replied by MFolks on topic 1974 z1 fuel injection?
I'd ask here:
www.msefi.com
Someone I believe here, did FI on a Kz650, it should be in the history. You'd need the sensor's:
Fuel injection computer.
TPS(throttle position sensor).
Air temperature sensor.
Engine temperature sensor.
Fuel pump.
Fuel pump filter.
4 injectors.
Possibly could use throttle body injector mounts on the engines intake side.
One way return valve to the fuel tank to maintain fuel pressure.
Fuel pressure regulator.
At least fuel lines rated to 40 PSI.
Related wiring.
www.msefi.com
Fuel pump.
Fuel pump filter.
4 injectors.
Related wiring.
- steell
15 Sep 2011 12:26 #477037
by steell
Replied by steell on topic 1974 z1 fuel injection?
That's Dave Sloan with the awesome fuel injected KZ650.
And here's a list of bikes that have been converted using MegaSquirt.
MegaSquirt Motorcycle Success Stories
