i have two bikes. a 83 kn1100ad2 and a 85 zn700ltd. the oringinal carbs on the 700 has ripped diaphrams. the 1100 cant be put back on the road. so i took the carbs off the 1100 and put them on the 700. bike will not run unless its on full choke. also it will not start unless you spray it. will these carbs work on the bike if so what are problems that i can fix.
