- Thank you received: 17
vacuum
- gengomerpyle
13 Sep 2011 14:53 #476407
by gengomerpyle
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
vacuum was created by gengomerpyle
on my carbs i just noticed that between carbs 1+2 and between 3+4 their used to be vacuum hoses hook to them with the emissions crap. my bike doesnt have the emissions on it any more and i just noticed they are not capped off. should i put caps on them or does it matter?
1982 GPZ750R1 ELR
1971 Honda CB750K
- roy-b-boy-b
- Thank you received: 103
13 Sep 2011 14:56 #476408
by roy-b-boy-b
Replied by roy-b-boy-b on topic vacuum
I think those are vents. Don't cap them. Roy
- gengomerpyle
13 Sep 2011 14:57 #476410
by gengomerpyle
1982 GPZ750R1 ELR
1971 Honda CB750K
Replied by gengomerpyle on topic vacuum
ok thanks
1982 GPZ750R1 ELR
1971 Honda CB750K
- okltree0
13 Sep 2011 16:43 #476429
by okltree0
Replied by okltree0 on topic vacuum
on no. 3 carb there is a cent that needs capped. no 1 and 4 are crossover that you do not cap and the vent on no 2 goes to the tank.
- gengomerpyle
13 Sep 2011 16:49 #476431
by gengomerpyle
1982 GPZ750R1 ELR
1971 Honda CB750K
this is on the air filter side of carbs, they seem for pivot when you push them. the vacuum ports are capped on the side closest to the intakes
okltree0 wrote: on no. 3 carb there is a cent that needs capped. no 1 and 4 are crossover that you do not cap and the vent on no 2 goes to the tank.
1982 GPZ750R1 ELR
1971 Honda CB750K
- Thank you received: 2098
- gengomerpyle
13 Sep 2011 16:55 - 13 Sep 2011 16:57 #476434
by gengomerpyle
1982 GPZ750R1 ELR
1971 Honda CB750K
1982 GPZ750R1 ELR
1971 Honda CB750K
Last edit: 13 Sep 2011 16:57 by gengomerpyle.
- Thank you received: 1656
13 Sep 2011 17:34 - 22 Jan 2013 03:41 #476438
by martin_csr
Last edit: 22 Jan 2013 03:41 by martin_csr.
