Another Leaking Petcock Question
  • mwriders
  • Topic Author
  • if I only had a brain
13 Sep 2011 13:23 #476378 by mwriders
Another Leaking Petcock Question was created by mwriders
Yep, the petcock on my KZ440B1 is leaking. This is a single hose vacuum unit (the non-functioning vacuum fitting is factory sealed). I rebuilt it with a standard kit last winter. The leak, (as near as I can tell from touch, sight and staining) appears to be at the connection to the tank. Now, I cleaned the tank and have a new 'O' ring from the kit. So, either the fitment to the tank is bad (pitted tank, maybe)or it is leaking around the bolts. I'm looking for an easy fix here. A chemical solution would be really nice (e.g. fast). Can I wrap the bolt threads in something? Use a sealant along with the 'O' ring?
1980 Kawasaki KZ440B (brand new eBaby)
1998 Ducati 900S (gone)
1978 BMW R100S (gone, damn it)
1975 Yamaha RD350 cafe (gone)
1986 Yamaha XJ650 Seca (gone)
1981 Kawasaki KZ440LTD (gone)
1969 HD Sportster (gone :)
1966 Honda CB160 (gone, damn it)
1965 Suzuki 80
13 Sep 2011 13:37 #476385 by Patton
Replied by Patton on topic Another Leaking Petcock Question
mwriders wrote: Yep, the petcock on my KZ440B1 is leaking. This is a single hose vacuum unit (the non-functioning vacuum fitting is factory sealed). I rebuilt it with a standard kit last winter. The leak, (as near as I can tell from touch, sight and staining) appears to be at the connection to the tank. Now, I cleaned the tank and have a new 'O' ring from the kit. So, either the fitment to the tank is bad (pitted tank, maybe)or it is leaking around the bolts. I'm looking for an easy fix here. A chemical solution would be really nice (e.g. fast). Can I wrap the bolt threads in something? Use a sealant along with the 'O' ring?
single hose vacuum unit (the non-functioning vacuum fitting is factory sealed) --- :huh:
  • mwriders
  • Topic Author
13 Sep 2011 13:51 #476388 by mwriders
Replied by mwriders on topic Another Leaking Petcock Question
Some 440's run two lines from the petcock, some run a single fuel line to an spigot located between the carbs. This one is the latter. They apparently use the same petcock, and just seal off the unused spigot at the petcock.
1965 Suzuki 80
13 Sep 2011 14:25 #476397 by Patton
Some ideas here ---
Click > www.arboristsite.com/chainsaw/133284.htm
Good Fortune! :)
The following user(s) said Thank You: mwriders
13 Sep 2011 14:27 - 13 Sep 2011 14:28 #476398 by Patton
Last edit: 13 Sep 2011 14:28 by Patton.
  • mwriders
  • Topic Author
13 Sep 2011 14:32 #476402 by mwriders
Cool. That stuff ought to work in this application. Thanks!
1965 Suzuki 80
