Petcock replacing?
- joeemac
12 Sep 2011 22:34 #476238
by joeemac
Petcock replacing? was created by joeemac
I have a 1981 KZ 440 A. I have changed the gas tank to a older sportster tank. I was wondering if i could use a sporty petcock or do i need the one from my orignal tank? The petcock from the kz has 2 fuel lines on it? Please if someone could tell me that would be great.
- Thank you received: 2098
12 Sep 2011 23:05 - 12 Sep 2011 23:06 #476255
by Patton
Where functional petcock has single fuel outlet and bike carbs have dual fuel inlets, may insert a tee fitting in the fuel line between the petcock and carbs.
Click here > www.z1enterprises.com/searchresult.aspx?...KeyWords=fuel%20line
Replied by Patton on topic Petcock replacing?
joeemac wrote: I have a 1981 KZ 440 A. I have changed the gas tank to a older sportster tank. I was wondering if i could use a sporty petcock or do i need the one from my orignal tank? The petcock from the kz has 2 fuel lines on it? Please if someone could tell me that would be great.
Last edit: 12 Sep 2011 23:06 by Patton.
The following user(s) said Thank You: joeemac
- Thank you received: 1656
13 Sep 2011 10:17 - 22 Jan 2013 03:43 #476348
by martin_csr
Last edit: 22 Jan 2013 03:43 by martin_csr.
