What fuel line to use for aftermarket petcock?
- Kapahulu
and it seems like a great alternative to Pingels, which cost about $100.
Now I realize the bung is 5/16" vs. 1/4" for normal petcocks on a KZ. I tried pushing the standard fuel line on it and I think the line might split. Alternate plans are to see if there's a reducer fitting that goes from 5/16" down to 1/4" (anybody seen one?) or grind down the edge of the bung on the petcock to get the fuel line on easier and then use a hose clamp to keep the fuel line on.
Who's come up with a good solution for this?
2strokeworld.com
- Thank you received: 2098
ribetautoparts.com/nylon-fuel-line-tubin...1-4-to-5-16-8mm.aspx
Likely available at hardware stores.
- Kapahulu
2strokeworld.com
- Kapahulu
Maybe I'll check the local hardware stores as Patton suggests.
2strokeworld.com
- JR
- Thank you received: 449
Sometimes this works so well that a clamp isn't needed.
- AtLarge
- Thank you received: 21
Patton wrote: Can try soaking the end of the 1/4" line for a few moments in near boiling water to soften it just before pushing it onto the larger barb.
Heat gun for peeling paint or a hair blow dryer on high to soften it up first? I've used both with good results.
1973 Honda CL70-K3
1975 Kawasaki 350 F9-C
1983 Kawasaki KZ750-K1
1994 BMW K1100RS
2008 Suzuki GSX1300-BKK8 #1120
- Motor Head
- Thank you received: 391
- Kapahulu
I'm liking the idea of sanding down the barb on the petcock, warming up the 1/4 inch fuel line and seeing if it will fit.
Thanks, Mike
2strokeworld.com
Kapahulu wrote: ...would imagine the Harley dealer sells it but then a foot will probably cost $10 bucks....
That's likely pretty good quality fuel line at the HD dealership, and perhaps not all that over-priced.
I'd check on it.
Some of the HD accessories are quite good.
