Lots of vibration...
- Suprum
15 May 2006 11:26
I just had my carbs cleaned and syncronized. The cold start problem i was having is now gone...Woo hoo!
But, i have noticed an excess of vibration and a loss of power at the top end.
Any thoughts?
Thanks
Any thoughts?
Thanks
- Fossil
Re: Lots of vibration...
15 May 2006 11:40
I'ld go back and see whoever did your carb work and explain the problem. Sounds like a sync or maybe even a fuel starvation problem. How do the plugs look? Are any of your exhaust pipes running cooler than the others? Does the bike sound right?
- anarki650
15 May 2006 11:40
Not sure what kind of set up you're running, but I had a noticable loss of power in the high r's on my 77 kz650b1 until I changed the primary jets up a step. Not sure why it'd have done that to you after cleaning and synching, but my problem stemmed from the wrong jet sizes. Hope it helps.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Omaha NE
