750-H throttle cable
- Bwildcat
31 Aug 2011 00:45 #473093
by Bwildcat
1980 KZ750-H LTD (first bike)
750-H throttle cable was created by Bwildcat
Not having a lot of luck... does anyone know special tricks to get the kz750-H throttle cable re-installed? Either I've got hands that are entirely too big or I'm missing something pretty significant. Spent all night messing with it with very little luck.
Just checking. Might be a "be patient" type fix but I don't want to miss something.
- kzcafe750_24
12 Sep 2011 00:32 #476057
by kzcafe750_24
1981 Kz 750-4 LTD - Wiseco 810 Big Bore,Ported cylinder head, GPZ 750 Cams,Dyna Ignition(DynaS,Green Coils,DRL400 2stage Revlimiter), RC 4 into 1 fitted with Yoshi muffler, ZR550 Swing arm, ZR550 Rear Rim, ZX750turbo front end SuperFlo Dyno Tuned- 68WHP&43WTq(ftlbs)
1986 Honda Rebel 250 (Stock)
1985...
Replied by kzcafe750_24 on topic 750-H throttle cable
Before you put the carbs in the place in the boots, I usually put the throttle cable on, first use your thumb to open the throttle valves open, then pop the cable in place, then put the carbs in place; should be set to go
1985...
- Tommotbird
12 Sep 2011 06:39 #476085
by Tommotbird
Triumph Thunderbird Sport
Triumph Legend
Lambretta SX150
Moto Guzzi V11 Sport
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
Replied by Tommotbird on topic 750-H throttle cable
Not an easy fix with the carbs in place on the bike. However I have managed to do it by working from the left hand side of the bike. Open the the throttle valves and wedge something like a rattle can top to keep them open. The cable should be free and not attached at the throttle end. You can then fit the cable nipple into the its place on the carb sort of upside down. Once in place feed the throttle end of the cable up and through- quite tight but it can be done. Nearly impossible to do it from the top even with the throttle valves wedged open.
Triumph Legend
Lambretta SX150
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
- Proxy
- 80% Human 20% Nuts/Bolts
- Thank you received: 46
12 Sep 2011 09:25 #476093
by Proxy
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
Replied by Proxy on topic 750-H throttle cable
Know any nurses? Get a nice pair of curved forcepts (hemostats). Best tiny hands(clamps) in the world. You can also get them off Ebay or Amazon.
- JR
- Thank you received: 449
12 Sep 2011 12:46 - 12 Sep 2011 12:47 #476117
by JR
Replied by JR on topic 750-H throttle cable
on my 1980 750/4 E1 I have to attach at the handlebar first.
Take the gas tank off, take the carbs off and then fiddle about from the left hand side like the guys above said. I like the idea of using a haemostat. I had to replace a throttle cable on the side of the road a few months ago. I always carry spare clutch and throttle cables.
Last edit: 12 Sep 2011 12:47 by JR.
