Dirty Carbs
  • n8miller
  • Topic Author
  • '82 KZ 750 LTD H3
29 Aug 2011 14:21 #472551 by n8miller
Dirty Carbs was created by n8miller
My floats keep getting stuck due to dirt in the carbs, but I'm not sure where it's coming from. I have an in line fuel filter, I've lined my tank and am running pod air filters.
Any ideas?
Thx.
29 Aug 2011 14:26 #472553 by roy-b-boy-b
Replied by roy-b-boy-b on topic Dirty Carbs
Are you using a paper filter?
I always use a long piece of fuel line that is clear and make a huge "U" in the line below the carbs so I can see what is in the fuel tank.I run my bikes like this all the time.
Do you have dirt dobbers in your area that could have got in the tank when the tank was dry? Roy
  • n8miller
  • Topic Author
  • '82 KZ 750 LTD H3
29 Aug 2011 15:40 #472578 by n8miller
Replied by n8miller on topic Dirty Carbs
Thx Roy.
It's not paper, it's one of these: www.z1enterprises.com/Fuel-Filter--High-...ne-clear-14-293.aspx
I don't think any dobbers could have gotten in it. Kept the tank in a pretty clean area the entire time. The tank was also lined in the spring and has had multiple rinses and tank refills since.
So you run the fuel line in a downwards U from the tank, hanging below the carbs and back up?
29 Aug 2011 16:05 #472585 by roy-b-boy-b
Yes, I started doing that a long time ago. I have had tanks with very fine rust and would have to disconnect the fuel line and dump the rust out several times before I got a clear line.
That way I can see what is going on. Roy
The following user(s) said Thank You: n8miller
29 Aug 2011 17:30 #472610 by jonnybravo
Replied by jonnybravo on topic Dirty Carbs
did u put on different lines?? perhaps some curd in there
