Carb bowl screw size
27 Aug 2011 09:32 #472113 by SlowRoad
Carb bowl screw size was created by SlowRoad
I am ordering a stage 3 jet kit from z1enterprises and want to order new bowl screws for my 81 kz1100. Is there a place to find, or can someone tell me what size these screws are? They only have them listed by size and not by application.
Thanks
1981 KZ1100-A1 Shaft
1997 Valkyrie GL1500
1998 KLR650
1978 KZ750-B Twin
  • trianglelaguna
27 Aug 2011 09:56 #472117 by trianglelaguna
Replied by trianglelaguna on topic Carb bowl screw size
in the shop manual there is a conversion/threads/mm/length chart and diagrams-count sheet for the kawis and the model req ect...right???
Z-1 will know what ones to give you...or you could just pull one and go match it in the bolts bins at any higher end hard ware...mom and pop ones are best and may have the exact count/material choices...ss...galv..ect...and mmm...cheap too
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
27 Aug 2011 10:00 #472118 by Patton
Replied by Patton on topic Carb bowl screw size
SlowRoad wrote: I am ordering a stage 3 jet kit from z1enterprises and want to order new bowl screws for my 81 kz1100. Is there a place to find, or can someone tell me what size these screws are? They only have them listed by size and not by application.
Thanks
For 1989 KZ1100-A1 shaft, kawasaki.com lists the carb bowl attachment screws as 5x14 pan head screw.
Some owners prefer replacing the pan heads with allen heads.
Lots of good info on kawasaki.com, including parts diagrams, part numbers, models sharing same part, availability, etc.
Here's a link for help with navigating the site and finding information.
kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
Good Fortune! :)
27 Aug 2011 10:07 #472120 by Charlie650
Replied by Charlie650 on topic Carb bowl screw size
5mm sounds rather large. I just bought new float bowl screws for my Mikuni VM24 carbs and they were 3mm x 16mm. I know VM26 use the same size too.
1977 KZ650C1
1975 H1F 500 Triple
2005 ZX10R
Sheffield(ish) UK
27 Aug 2011 10:37 #472125 by SlowRoad
Replied by SlowRoad on topic Carb bowl screw size
I like that idea!! Think I will try to find some locally. Just ordered the Stage 3 kit!!
1998 KLR650
1978 KZ750-B Twin
27 Aug 2011 11:04 #472129 by Patton
Might also check with KZr member wireman for info about the allen heads.
Good Fortune! :)
