Carb identification
- pg4827
Carb identification
27 Oct 2005 13:47
What does [/u]VM26 stand for<
Were can you find what kind of Carb it is?
(ie;stamped,or labled)
- mariozappa
Re: Carb identification
27 Oct 2005 13:55
I believe the 26 indicates 26 millimeters across the inside diameter of the carb on the engine side.
V? venturi?
V? venturi?
1977 KZ650C1
and the KZ650/KZ750 Conversion
- savedrider
- 1975 Z1-B 900
27 Oct 2005 17:35
You won't find VM26 stamped on the carbs. There are other numbers though and you can cross reference those to the type of carbs you have. Easiest though (as already mentioned) is to measure the ID of the engine side of the carbs.
Get right or get left! <*{{{><
- DanOz7Five0
27 Oct 2005 18:35
savedrider wrote:
kzrider.com/forum/viewthread.php?tid=29912
I thought the same thing. It turned out that the carbs I was always thinking were VM26 are VM24s
Post the code you can find on the flange on the right side of the carb body (the part sitting on the stool in this picture)and maybe someone can help you more.
- wiredgeorge
28 Oct 2005 06:12
VM is a Mikuni series of carburetors where the slides are round and mechanical. The 26 is, as has been pointed out, the inner diameter size of venturi which seats in your intake manifolds. It will actually read about 26.7mm if you measure with a caliper. The 1978 KZ1000 family came with standard VM26 carburetors while the Z1R came with similar but larger VM28 carburetors. There is an ID mark on the flange of your assembly that is used by the manufacturer to identify it. On some, there are different marks on each end but only one identifies the assembly. The other is used to ID that particular carburetor as each carb has a mark as well in the same location. To read an ID mark, clean the area good as they are typically shallow and hard to read. Yours will read as follows:
102
5A
102
5A
- bluej58
06 Nov 2015 13:15 - 06 Nov 2015 13:17
Wow, I found an old one, can someone post any other threads on VM26 identification with pictures?
VM28's too please
VM28's too please
78 KZ1000 A2A
Last edit: 06 Nov 2015 13:17 by bluej58.
