carb sync question.
  • Motor Head
26 Aug 2011 12:39 #471941 by Motor Head
Replied by Motor Head on topic carb sync question.
Well that dia, did you use a drill for a gauge? Is that exact? From what I see that is larger than the #32 Drill listed in the Dyno Jet kit, which is .1155".
Yes a hole in the Diaphragm is bad, it will cause the slide to rise slower than the others, less fuel from the needle jet circuit, and probably a hesitation on that cylinder.
26 Aug 2011 12:56 #471943 by garyprather
Replied by garyprather on topic carb sync question.
it was most likely a .1155 but it drilled over.
11 Sep 2011 17:44 #475965 by garyprather
I recently checked my jets and they installed 140 and 160's does that sound about right for the bike I have with mac 4 into 1 with pod filters
  • mark1122
  • Keep twisting it
11 Sep 2011 17:56 #475970 by mark1122
Replied by mark1122 on topic carb sync question.
if u have a hole in the diaphram, u will want to get that fixed before u adjust anything else.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
11 Sep 2011 18:52 #475984 by garyprather
some gorilla glue cured that issue.
12 Sep 2011 13:45 #476126 by garyprather
I was wondering if the jetting I specified was about correct for my 83 spectre 1100?
