- Thank you received: 10
KZ1000 popps... ALOT
- Kitten Tooth
Thanks guys,
KT
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- mtbspeedfreak
- Thank you received: 36
Kitten Tooth wrote: This is kind of an exhaust and carburetor issue so i just put it on this part of the forum.. i recently installed a Kerker 4 into 1 on my 1981 KZ1000LTD. the bike runs like a monster. But, no matter what gear or RPM your at, when you let off the throttle it popps a whole bunch as the RPMs decrease. when you pull out the choke to the halfway mark, it doesnt pop at all. I know its running lean and i have made the conclusion that i have to jet up since messing w/ the pilot circuit screws didnt help. Im just wondering if i ride it with half choke as a bandaid till i get a jet kit, can i screw anything up by doing that? Also, the insulator on the spark plug for cylinder 4 is totally white and it looks like its got really hot before.. i also have loose valve clearances because you can hear them chattering on that side of the motor. i plan on getting these things fixed soon but in your guys' opinion, should i stop riding it until then?
Thanks guys,
KT
So those are all symptoms of running lean. Makes sense as the 4-into-1 flows better than the stock exhaust. I remember my exhaust was popping quite a bit on downshifts due to a lean condition caused by worn out carb to head intake boots. Next time you have your carbs off, wouldn't hurt to check them out as well.
2000 ZRX 1100
1976 KZ 900- Daily Driver
- bountyhunter
- Thank you received: 337
- roy-b-boy-b
- Thank you received: 103
- Old Man Rock
- Thank you received: 225
Possibly will give you some insight...
NOTE: Do one jetting at a time, run & test before going to the others.... Best to start with Main, then pilot then needles...
Once Main and pilots are pretty much dialed in, for needles run at 65mph, she surge a tad, or... @ 65mph let go of the throttle, she back fire/pop.... If so, still too lean... Change clip position or needle pending your configurations.
Also, keep in mind with summer temps, humidity etc....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- TeK9iNe
- What did you do!?!
- Thank you received: 28
If you have the CV style carbs associated with the 81 year bikes, then all you have to do is add a little fuel the the idle circuit via your good ol' mixture screws.
Turn them richer by 1/4 turn and test - AS LONG AS THERE AR NO AIR LEAKS PRESENT ANYWHERE, the popping will decrease quickly with each turn. When the popping has ceased completely, add an additional 1/4 turn - and your done.
If you change the pilot on those carbs, the cruise position will become very narrow and jerky with a 4-1 header.
If you have slide carbs, well usually an air/mix screw adjustment will suffice - but MAYBE 1 pilot up would be required - and never more.
I've done this on japs and hardleys for years when aftermarket pipes are added.
Good luck friend.
Just my 2 cents! PEACE.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Kitten Tooth
Thanks for all the help so far guys,
KT
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- TeK9iNe
Are the valve clearances all good? Good compression?
Could be poor throttle body/slide balance - pull the carbs and do a bench sync at least if you havnt.
Fuel height is ok on all carbs? Carbs have been thoroughly cleaned by verifying the flow of cleaner through all the passages/pilot holes into the bores?
Neeeeed more info :laugh: Tried swapping/new plug???
Sad thing is really... if you dont do ALL of these things, then it will run poorly. You cant skip a single step of a real good carburetor tune and setup.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Kitten Tooth
cylinder 2- 125PSI
cylinder 3- 125PSI
cylinder 4- 135PSI
Thats what i got for compression. im thinking that the inner cylinders are a wee bit low considering these bikes come off the line with like 170psi compression... hopefully thats due to my bad valve adjustments.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- nads.com
- Thank you received: 20
Light a ligher and hold it in front of each pipe.
How much did you turn the pilots out?
The motor is going to need them opened about a full turn more to get rid of that pop.
With the cams and pipe it's not getting enough gas.
The lean factory settings are out the window.
If you aren't running a baffle it's gonna need more fuel for idle.
You can look forward to alot more snap once you richen up the pilot circuit with the screws.
