KZ1100 runs with enricher on only
- dabarnguywi
Rex
1982 KZ1100-A2 Shaft: Kerker 4 into 1, Vetter QuikSilver faring & bags
1996 Voyager XII
1967 HD Electra Glide
1971 Allis 314
1978 Allis 716
1982 Allis 916 w/barn made front end loader
- Motor Head
- Thank you received: 391
Those would be Mikuni BS34 CV carbs. When you slap Pods on and remove the stock AirBox, you have changed the signal to the carb dramatically. Either put the Stock Airbox back in with new connecting boots, or be willing to try to make it run with the Pods. Do a search, many opinions on this subject.
- roy-b-boy-b
- Thank you received: 103
- dabarnguywi
Rex
1996 Voyager XII
1971 Allis 314
1978 Allis 716
- dabarnguywi
Rex
1996 Voyager XII
1971 Allis 314
1978 Allis 716
- roy-b-boy-b
The jetting sounds good. It should run if it were getting gas through the pilots. Roy
- Motor Head
Two things, first go to your profile, and add your model to your signature. It will help with reply's.dabarnguywi wrote: Thanks Motor Head... I had read about the pod issue, had no idea it was that dramatic. I bought some used boots (said in ex cond) from fleabay, they weren't any better than mine... do you know if the boots are available aftermarket as repo ?
Rex
Z1 will have new boots for your Airbox, and intake manifolds. www.z1enterprises.com/catalog.aspx?pid=KZ1100
Choose your year and model, and off you go. they have fair prices and excellent service. Cab kits, jets, etc.
- dabarnguywi
1996 Voyager XII
1971 Allis 314
1978 Allis 716
- dabarnguywi
1996 Voyager XII
1971 Allis 314
1978 Allis 716
- dabarnguywi
1996 Voyager XII
1971 Allis 314
1978 Allis 716
- roy-b-boy-b
dabarnguywi wrote: I went back down to the barn, took a look at a spare carb... I think I'll pull the carbs off the bike again and make sure the hole between the main jet tubes and the pilot tubes are clear...
That was my next suggestion. Roy
- Motor Head
Also Air leaks at the Intake manifolds/ carb holders, are there any?
having the Pod's on there will make it quite lean. Without re-jetting, maybe just double check your manifolds and carbs while waiting for the Air Boots. It will be easier to do any trouble shooting with it stock, since the jets are. Or have you checked the jet sizes against the manual? I have a link in my signature for a pdf free download if needed.
Don't forget the Float Height, then Fuel level clear tube test. Get them all nice and even.
