Jet sizes kz1100
- fergieuk
07 Aug 2011 13:55 #467482
by fergieuk
KZ1100D1
Jet sizes kz1100 was created by fergieuk
Anybody know the upjet sizes for running k&n's with pipes with next to no baffle? Want to run it rich so I don't melt the pistons.
Cheers
Fergie
Cheers
Fergie
KZ1100D1
- Motor Head
- Thank you received: 391
07 Aug 2011 14:07 #467484
by Motor Head
Replied by Motor Head on topic Jet sizes kz1100
You should do 2 things, 1st add the year and model info to your user profile signature so it will show up with each post. This will help everyone give you the response you want.
Then second if you go here; www.kawasaki.com/DefaultFrame.aspx?strCo.../VICHOOSEVEHICLE.ASP
Fill in the info for your bike it will come back with the parts diagram and list. It should show you the stock jetting for your bike, I believe it will be 117 main jets in the stock BS34 carbs. I run 122.5 mains in my 1000 with the same carbs and a 4-1 Vance and Hines. I also upped the stock pilot jets to 40's. Each bike and conditions are a bit different. You may find 127 mains suitable.
- otakar
07 Aug 2011 14:12 #467485
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Jet sizes kz1100
A good start point with what you have described is 4 sizes over stock.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- fergieuk
07 Aug 2011 14:30 #467494
by fergieuk
KZ1100D1
Replied by fergieuk on topic Jet sizes kz1100
Cheers Motor Head. Will edit my profile once I get on a big computer type thing. Tend to do this from iPhone at work so as to keep mrs Fergie off my case. Lol.
KZ1100D1
- Motor Head
07 Aug 2011 14:34 #467497
by Motor Head
Then you can post some pictures, and put in an avatar.
Good luck.
Good luck.
- havakaw
- Thank you received: 27
07 Aug 2011 18:17 #467534
by havakaw
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
Replied by havakaw on topic Jet sizes kz1100
I got the Dyno-Jet Jet kit for mine,raised the needles 1 clip spot down from suggested,and went with 142 big head main.The 155 small heads that came with the kit were too rich for me.
'80 KZ 750 LTD-H
