bs 34 carbs???
06 Aug 2011 11:21 #467204 by 79kz1000*
bs 34 carbs??? was created by 79kz1000*
Was wanting to know what all u would have to do to put these on my 79 kz1000 ltd b3?? Looking to buy a set of these an just wanted to know if I might need different cable or anything??? I know ill need the intake boots thanks fir the help
79 kz 1000 ltd
76 kz 900
06 Aug 2011 11:31 - 06 Aug 2011 11:33 #467206 by otakar
Replied by otakar on topic bs 34 carbs???
Just the manifolds, filters, and main jets. I would get the manifolds for a GPz750 for your application. I would also jet the carbs for the GPz750 to start. if you can get a set of 34s that came from a GPz750 would be even better unless you expect to do some major engine work.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 06 Aug 2011 11:33 by otakar.
06 Aug 2011 14:36 #467241 by 79kz1000*
Replied by 79kz1000* on topic bs 34 carbs???
It already has motor work to it. Its suppose to b a 1260cc mtc block web cams wesico pistons!!! Thank you for the help man
79 kz 1000 ltd
76 kz 900
06 Aug 2011 15:29 - 06 Aug 2011 15:30 #467251 by otakar
If it has that much work and the motor is that big I hope that there is some serious head porting done to be able to breathe a motor that big. If so than those are the wrong carbs. You should be looking for a set of smooth bores. The VM33 or larger carb for a motor that big.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 06 Aug 2011 15:30 by otakar.
06 Aug 2011 15:33 #467252 by otakar
Dont make the assumption that the BS34s are larger than the VM33s. Not even close. The BS carb is a ventury carb and flows like a 31mm smooth bore.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
06 Aug 2011 17:16 #467276 by 79kz1000*
Thanks for all the help!!! I understand what ur saying thanks again
79 kz 1000 ltd
76 kz 900
07 Aug 2011 19:27 #467542 by cavanaughracing
Replied by cavanaughracing on topic bs 34 carbs???
otakar wrote: If it has that much work and the motor is that big I hope that there is some serious head porting done to be able to breathe a motor that big. If so than those are the wrong carbs. You should be looking for a set of smooth bores. The VM33 or larger carb for a motor that big.
:ohmy:
07 Aug 2011 21:33 #467573 by otakar
:ohmy:
;) :whistle: After all it's a 1260. I'd put smooth bores on a motor that big too. :blush:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
09 Aug 2011 17:13 #468041 by cavanaughracing
:lol: Dam....you fall out of bed and bump your head or something ?
09 Aug 2011 18:25 #468054 by otakar
Must have been those bad drugs I did the other day. (I think the Aspirin bottle said it was expired.);) :laugh: I also think I made an error and washed it down with a caffeinated pop instead of water. :silly: :whistle:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • TeK9iNe
  • What did you do!?!
09 Aug 2011 18:46 #468058 by TeK9iNe
Replied by TeK9iNe on topic bs 34 carbs???
otakar wrote: Must have been those bad drugs I did the other day. (I think the Aspirin bottle said it was expired.);) :laugh: I also think I made an error and washed it down with a caffeinated pop instead of water. :silly: :whistle:
Yummy... I keep said items at my bedside as the ultimate bed time hangover cure.
...and if you dont wake up, well - still no hangover! :woohoo:
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
