convert vaccuum petcock to standard petcock
  • cobura
  • Topic Author
  • forever 2 wheels
05 Aug 2011 10:47 #466998 by cobura
Another quick question. My 650 has a leaky vaccuum actuated petcock. I have never been a fan of the vaccuum type, so I was wondering, can I just replace it with a standard ON/OFF petcock such as a pingel? Or is my carburettor designed to work only with a vaccuum type?
If I can use a standard ON/OFF petcock, do you happen to know what size I need. I had a pingel on my previous KZ650 B1, so I know there is one that will fit. Thanks!
1979 KZ650B3
05 Aug 2011 10:56 - 22 Jan 2013 03:25 #466999 by martin_csr
Replied by martin_csr on topic .
Last edit: 22 Jan 2013 03:25 by martin_csr.
The following user(s) said Thank You: cobura
05 Aug 2011 11:20 #467007 by Patton
Replied by Patton on topic convert vaccuum petcock to standard petcock
Z1E may have a suitable manual petcock and adapter plate.
Good Fortune! :)
05 Aug 2011 11:22 #467008 by Patton
05 Aug 2011 12:01 #467018 by TexasKZ
Replied by TexasKZ on topic convert vaccuum petcock to standard petcock
Be sure to plug the vacuum port on the carb if you go the manual route.
  • cobura
  • Topic Author
  • forever 2 wheels
05 Aug 2011 12:17 #467023 by cobura
Replied by cobura on topic convert vaccuum petcock to standard petcock
Thanks, those petcocks on Z1E look like a good alternative to the more expensive pingel.
1979 KZ650B3
05 Aug 2011 17:37 #467065 by cdvanns
Replied by cdvanns on topic convert vaccuum petcock to standard petcock
I just upgraded from 26mm to 28mm carbs. on my 78 KZ1000 and I used Z1's manual petcock for the switch from vacuum and I gotta say it's a quality product at a great price!
1978 KZ1000 A2
05 Aug 2011 17:44 #467069 by roy-b-boy-b
Replied by roy-b-boy-b on topic convert vaccuum petcock to standard petcock
I bought a petcock from Z1E with the adapter plate and I like it. Roy
