Bs34, ANYONE WITH PODS? PLEASE HELP!
- KzChop82
I have an 82 kz 1000 csr engine with bs34 carbs. I am trying to put my k&n pods onto the carbs, but there seems to be an issue with the sizes. The filter pods rubber lip is almost exactly the same diameter as the carb where they are supposed to be mounted, and I can't get them on.
Has anyone else ever had this problem?
Does anyone have pictures of how they mounted the pods to the carbs?
Am I supposed to use the rubber booties from the original air box?
Any help or pictures would be appreciated,
Thanks-
Clinton, NJ
Custom chopper, 1982 KZ 1000 M2 CSR engine, K&N Pod Filters
PICTURES AND GOPRO VIDEOS!! :
www.dropbox.com/sh/jipz3l8nhzr4jge/AABbm...OC3sqlhCSLxH5Fa?dl=0
- steell
650ed wrote: In that case, make that 3 bottles of Scotch and a bucket full of jets and needles. Oh, and don't throw out the airbox or it's hardware, either you or the next owner will want to put it back.
But if you must, then it sounds like you have the wrong filters.
And you might want to save this post from another thread
TeK9iNe wrote: Admittadly - I've had the most difficulty with the setup you have just described.
125 would be far too much - try 112 - 117 to begin with.
You may not have to change the pilot jets - just turn out the mixture screws about 3 for starters
All depends on your engine and requirements with this application. You will be tuning and fiddling for many hours to come...
Might be best to get a jet kit that has properly tapered needles and a drill to change the slide rate.
The bike will never feel perfectly smooth again without an airbox - sorry, you may think it does after many hours spent tuning - but it wont be.
Good luck!
- roy-b-boy-b
- Thank you received: 103
- TeK9iNe
- What did you do!?!
- Thank you received: 28
roy-b-boy-b wrote: You should have 54mm filters. Roy
BLAST - you just beat me to it.
If they dont fit - heat em up and lube both surfaces, then squeeze them on there and clampem'
:laugh: ..or get the correct ones.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- garnermartin64
- otakar
EMGO # 12-55754
www.z1enterprises.com/Air-Filter-pod-54m...idual--EMGO-221.aspx
Here is a picture of the EMGO filters on my bike.
Attachment DSC01513_2011-08-04.JPG not found
Attachment DSC01681.JPG not found
Attachment DSC01687_2011-08-04.JPG not found
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- cavanaughracing
- Banned
Larry C.
cavanaughracing.com
- peter1958
- Banned
- Thank you received: 198
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- peter1958
- Banned
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
