Need help on my E-2 build
  • Chaotic Reason
  • Topic Author
01 Aug 2011 16:00 - 01 Aug 2011 16:03 #466194 by Chaotic Reason
Need help on my E-2 build was created by Chaotic Reason
So I was cleaning parts in an ultrasonic cleaner and thought, "Hey, if it does such a good job with just water, maybe putting in some degreaser will work much better?" Well, I'm not exactly sure what Mikuni carbs I have, but here is a picture:
Attachment DSCF0921.JPG not found
I put one of the slides in the bath and let it run, but when I took it out, it had purple foam all over it. I immediately cleaned it off, but it looked like this:
Attachment DSCF0947_2011-08-01.JPG not found
Attachment DSCF0948_2011-08-01.JPG not found
I sanded it with a fine sanding block and then rubbed some WD-40 on it, and it turned out like this:
Attachment DSCF0968_2011-08-01.JPG not found
Attachment DSCF0969_2011-08-01.JPG not found
Am I totally up a creek? Or will I pretty much have to try it and see if it's ok? Any ideas???
Michael
1980 KZ1000 shaft drive
Last edit: 01 Aug 2011 16:03 by Chaotic Reason.
02 Aug 2011 09:15 #466331 by SPARKY47
Replied by SPARKY47 on topic Need help on my E-2 build
What liquid did you use?
1980 KZ500 B2
  • Motor Head
02 Aug 2011 09:20 #466332 by Motor Head
Replied by Motor Head on topic Need help on my E-2 build
Ooop's looks like a replacement would be needed. It looks as though the coating was severely damaged.
Look for a good used one, maybe someone here can help you with a spare?
The following user(s) said Thank You: Chaotic Reason
02 Aug 2011 09:26 #466336 by Patton
Replied by Patton on topic Need help on my E-2 build
Chaotic Reason wrote: ...have to try it and see if it's ok?....
That's what I'd do, provided it slides easily up and down inside the carb.
Good Fortune! :)
  • Chaotic Reason
  • Topic Author
02 Aug 2011 09:54 #466339 by Chaotic Reason
Replied by Chaotic Reason on topic Need help on my E-2 build
I used "Super Clean" from Walmart. It's like that "Purple Power" stuff, but I forgot to read the back where it said to dilute it for chrome and stainless steel. I was using it straight to clean stuff. Well, the stuff WORKS!!! A gallon of it was under $8, so I figured what the heck. The nuts and bolts that had grease all over them, came out looking amazing. It didn't take off rust, but hey, it's rust, I just need to replace those bolts anyways. I just never expected it to take the coating off like that.
Michael
  • Motor Head
02 Aug 2011 10:12 #466342 by Motor Head
16025-1026 VALVE,THROTTLE,CA2.0 is the part, about $60 new.
Here is a NOS on Feebay: cgi.ebay.com/ebaymotors/NOS-Kawasaki-KZ-...&hash=item45f635cd2a
It fits several of models, so a used one should be easy to find. I wouldn't use that damaged one, as next your car bore will be damaged,. Also it may very well hang-up/ stick.
  • KZ_Rage
  • Kentucky Bourbon Barrel Ale
02 Aug 2011 10:13 #466343 by KZ_Rage
Replied by KZ_Rage on topic Need help on my E-2 build
I think it will work temporarily but if will get sticky faster from stuff depositing on the surface and in the pits. It might also wear on the bore of the carb body which wouldn't be good at all.
You might post a "want" ad here and/or contact some of the carb rebuilders in the vendors section to see if they have one to sell you possibly. Those should be the stock 28 pumpers (VM28SS). A complete set just sold on eBay for $91 + shipping to give you an idea of costs of just buying a slide versus buying a spare set.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
