fuel petcock
  • redneckcarrow
  • Topic Author
25 Jul 2011 20:16 #464882 by redneckcarrow
fuel petcock was created by redneckcarrow
found out the hard way today that my fuel petcock may be messed up lond story short ran out of gas on the way to work. left house fuel on on position started to run out so reached down and put petcack on reserve and still ran out of gas only good part was in site with a fuel station so just pushed bike over and put fuel in 3.188 gals so it must have been bone dry put back on on position startd right up whent to work.
now any ideas on fixing or am i french and put petcock in wrong position the handle goes to the back right? if it makes a differents the petcock has a vacuume hose on it (still not shure why it has one)
thanks guys
1980 kz 550 ltd stock
25 Jul 2011 21:13 #464894 by TexasKZ
Replied by TexasKZ on topic fuel petcock
French I guess.
The vacuum hose is an indication that you have a vacuum operated petcock. When working properly, this device prevents fuel flow when the engine is off, as long as the short end of the lever is pointed at ON (run) or RES (reserve). The PRI position will allow fuel to flow with the engine off, which is often helpful when trying to restart a bike that has run out of fuel or after a carb rebuild.
Based on what you wrote, I'd guess that the rascal was on PRI rather than ON or RUN when the bike quit running.
Legal disclaimer: I do not now nor have I ever owned a KZ550. My assumptions are base on ownership of various liter bikes.
  • redneckcarrow
  • Topic Author
25 Jul 2011 21:17 #464897 by redneckcarrow
Replied by redneckcarrow on topic fuel petcock
will have to look closer at petcock i guess
25 Jul 2011 21:38 #464903 by MFolks
Replied by MFolks on topic fuel petcock
The gas/alcohol mix sold is very nasty on rubber pieces of motorcycle fuel systems like the rubber tipped float valves,the diaphram of vacuum petcocks and other "O" rings.
  • redneckcarrow
  • Topic Author
26 Jul 2011 21:52 #465167 by redneckcarrow
i am a nuchel head been runing bike in pri posision so that exsplains why i ran out of gas but now i know thanks guys
27 Jul 2011 12:20 #465280 by KZJOE900
Replied by KZJOE900 on topic fuel petcock
Are you sure the petcock reserve tube it not getting clogged from bottom tank debris ? I had that happen to me but it was a none vacuum type. The normal "On" fuel tube gets the fuel at a higher fuel level than the reserve and not from the bottom of the tank, the reserve gets fuel all the way until the tank is empty. Therefore, the 'On' doesn't get clogged but at the same time the reserve can. Found out the hard way back in the early 80's driving (flying) across Alligator Alley at 2:00 in the morning. Had to have my buddy shine his bike's headlight on my tank while I took the petcock apart to clean the screen. Back then, there were no gas stations (nothing, only gators) for the whole 80 mi stretch. Once fixed, I was able to use my reserve for the last 20 mi. to Naples. Good luck.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
27 Jul 2011 13:31 #465288 by TexasKZ
I hope that solves the problem. With these old bikes, we all love a cheap and easy now and then.
  • redneckcarrow
  • Topic Author
27 Jul 2011 19:52 #465375 by redneckcarrow
easy fix a been running it on wrong setting on petcock
