- Thank you received: 1
HAVING AN ISSUE WITH GAS COMING FROM OVERFLOW HOSE
- 79kz1000*
25 Jul 2011 11:47 #464778
by 79kz1000*
79 kz 1000 ltd
76 kz 900
HAVING AN ISSUE WITH GAS COMING FROM OVERFLOW HOSE was created by 79kz1000*
Hey guys, im seem to be having an issue with fuel coming out of the overflow hoses!if you have the petcock to the on, it only leaks a little bit after you shut the bike off.Now if you put it to reserve it just pours out very bad!! i took carbs off thinking a float was stuck but when i pulled them off,they where fine! any help would be great thanks!!!
79 kz 1000 ltd
76 kz 900
- Thank you received: 2829
25 Jul 2011 12:20 #464786
by 650ed
Replied by 650ed on topic HAVING AN ISSUE WITH GAS COMING FROM OVERFLOW HOSE
Do all 4 carbs overflow? I would clean the float valve needles & orifices carefully with Q-tip and carb cleaner. If they still leak I would replace them. I suspect that the reason the fuel overflow is heavier when you put the petcock on reserve is that on reserve the petcock opens up a lower orifice inside the fuel tank. This means the pressure, which is relative to the top of the fuel in the tank to the petcock orifice that is open, is greater on reserve than in the normal position. The other possiblity is that the fuel level (float tangs) is set too high, but if the problem is on all 4 carbs that seems highly unlikely. Ed
- Thank you received: 2098
25 Jul 2011 12:20 #464787
by Patton
Probably a petcock issue PLUS problem(s) with float valve and/or float and/or float adjustment and/or float function and/or overflow tube crack.
Fuel may have entered the crankcase and contaminated the oil.
Would "sniff-test" the oil and examine its physical condition.
Replied by Patton on topic HAVING AN ISSUE WITH GAS COMING FROM OVERFLOW HOSE
79kz1000* wrote: Hey guys, im seem to be having an issue with fuel coming out of the overflow hoses!if you have the petcock to the on, it only leaks a little bit after you shut the bike off.Now if you put it to reserve it just pours out very bad!! i took carbs off thinking a float was stuck but when i pulled them off,they where fine! any help would be great thanks!!!
- 79kz1000*
25 Jul 2011 21:45 #464906
by 79kz1000*
79 kz 1000 ltd
76 kz 900
Replied by 79kz1000* on topic HAVING AN ISSUE WITH GAS COMING FROM OVERFLOW
Hey guys there was a lot of debris in buttom of the bowls an build up as well in the petcock!
I cleaned all of the carbs very well. Cylinders 3 &4 were pretty lean so I would have to say they
Were leaking. Cylinders 1 & 2 looked good, thanks for the help
79 kz 1000 ltd
76 kz 900
