Stuck float pin!!!
23 Jul 2011 20:47 #464514 by barquirt
Stuck float pin!!! was created by barquirt
I have a '74 KZ400 I'm bringing back after 27 years in poor storage. Carburetors are a mess. I have one completely apart, the second has a float pin that refuses to budge. I've been tapping at it with a center punch and all it seems i'm doing is wrecking the head of the pin on both sides.
Anybody been here before and found a good solution? I've been soaking the pin with cleaners and tapping at it for more than a week with zero results. HELP!
23 Jul 2011 20:54 #464516 by Patton
Replied by Patton on topic Stuck float pin!!!
If not already done, try soaking overnight in 50-50 solution of ATF and acetone.
Apply heat to pin locations with a propane torch immediately before gently tapping on the pin.
Be ultra careful not to break off a tower.
Good Fortune! :)
23 Jul 2011 22:17 #464529 by P21
Replied by P21 on topic Stuck float pin!!!
not to be a smart azz but you should use a BRASS punch not steel
also try BB-Blaster
Kawasaki KZ 1000 Police (2002) P21
24 Jul 2011 05:37 #464564 by Harvey1327
Replied by Harvey1327 on topic Stuck float pin!!!
Make sure you support the bottom float post where the pin is stuck.
I did not and mine broke off.:angry: :angry:
1 x 77 Z1000
1080,cams,ported
29 smoothbores,
Akron rims,Martin Swingarm
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
shotgun shock,corbin
seat,fat bars,some bling.
www.kzrider.com/media/kunena/attachments/8119/IMG_0461.JPG
24 Jul 2011 07:14 - 24 Jul 2011 07:19 #464568 by Patton
Would fab a support mechanism whereby both tower posts are simultaneously held in position while the pin is being pressed or tapped.
Pressing or tapping a pin on the end where it's "loose" in one post also applies pressure to the other post where the pin is "tight."
Good Fortune! :)
Last edit: 24 Jul 2011 07:19 by Patton.
24 Jul 2011 21:28 #464666 by bountyhunter
Replied by bountyhunter on topic Stuck float pin!!!
You can get a set of brass gunsmithing punches pretty cheap (like under $10) with all different diameters for smacking pins without destroying the head of the pin.
