keihnin cv34s
  • dynastydudge
  • Topic Author
23 Jul 2011 14:36 #464473 by dynastydudge
keihnin cv34s was created by dynastydudge
is the bowl vent tube do anything except drain the bowls if they get full?....or does it have another purpose?
were not here for a long time, just a good time......1980 kz750 ltd h1
1982 honda cm 450e
23 Jul 2011 15:13 #464476 by thug
Replied by thug on topic keihnin cv34s
If its the ones at the bottom you mean I think they,re just an overflow for the float bowls;)
KZ1100 A3 shaftie
  • dynastydudge
  • Topic Author
23 Jul 2011 17:08 #464493 by dynastydudge
Replied by dynastydudge on topic keihnin cv34s
ok cool....i have one thats broke...cant find a replacement right now. and i need to ride this bike.
1982 honda cm 450e
23 Jul 2011 22:22 #464531 by JR
Replied by JR on topic keihnin cv34s
Can you take a photo ?
Your carbs are probably the same as mine. If it is just the nipple that is broken on the bottom of the bowl you can maybe survive but if it's the brass tube inside the bowl that is broken then you have a problem - gas will pur right out. You can get similar brass tubing at a hobby shop.
Take the bowl off and fill with water and see what happens
