reserve
  • jacksdad
  • Topic Author
  • 1979 kz 750 OUCH, IT SPARKED
22 Jul 2011 11:29 #464244 by jacksdad
reserve was created by jacksdad
not sure where to put this,but since it involves the cabs here goes, last night as I was on my way home, about .75 miles from the house, I had to switch over to reserve which got me thinking, is it a good idea to burn all the fuel out every so often, or just keep the petcock in the on pos all the time?
1979 kz750 twin cyl.
  • RetroRiceRocketRider
  • ...bring in the machine that goes PING!
22 Jul 2011 11:45 #464245 by RetroRiceRocketRider
Replied by RetroRiceRocketRider on topic reserve
Runing all the fuel out won't do anything but force any debris in the tank to stick to the petcock filter inside the tank, and require you to use the PRI (prime) position on the petcock to refill the carb float bowls with fuel prior to restarting your bike.
Adding fresh fuel to fuel that's already in the tank is OK, they will mix together and burn just fine. Granted, you should make sure that the fuel already in the tank isn't stale prior to adding any fresh fuel. ;)
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
  • jacksdad
  • Topic Author
22 Jul 2011 12:09 #464247 by jacksdad
Replied by jacksdad on topic reserve
thanks, since I don't have a prime position, just on off and res. i'll fill er up today, this is what I had thought, but wanted re-assurance
22 Jul 2011 12:36 #464253 by loudhvx
Replied by loudhvx on topic reserve
Also, when winterizing, some people run the carbs out of gas until the bike stalls, instead of draining the bowls the regular way. Well the bike won't really "run on fumes", so it will stall before the bowls are empty. It's better to drain them out through the drains. In addtion to getting more of the gas out, draining the bowls when they are full will have more drain-flow which will bring more debris out with the gas.
  • jacksdad
  • Topic Author
23 Jul 2011 01:02 #464358 by jacksdad
yeah, about the drain plugs on the bowls, mine are stripped so bad that I am going to have to drill them out this winter, no leaks right now, and so far I think this is the best 350 dollars I have ever spent!!
